(1dec02) This issue will rerun an issue about rigging a balanced lugsail. The 15dec02 issue will mess around with motors.
Ari Haberberg's Mayfly14 in New York.
RIGGING A LUGSAIL
BASIC BALANCE....
TYING ON THE SAIL...
HALYARD/YARD ATTACHMENT...
THE TACK LINE....
THE SHEET...
SAILING ADVICE...
We'll mess with motors.
PICCUP PRAM
Here is another by Doug Bell:
Piccup Pram uses taped seam construction from five sheets of 1/4" plywood. Plans for Piccup are still $20.
An Australian builder has started a Dorado which is a power version of Frolic2. At the point of looking like a boat....
The Australian Twang builder looks about done to me:
The Oracle builder in St. Louis has his hull basically done except for finish, hard to do in the winter.
