(1jun02) This issue will rerun the ever important Sail Area Math essay . The 15jun02 issue will discuss making sails from polytarp.
THE 13th ANNUAL MIDWEST HOMEBUILT BOAT MESSABOUT will take place on June 8 and 9 at the Gun Creek Recreation Area at Rend Lake in Southern Illinois. Take exit 77W off I-57, head towards the golf course and you will see the signs. Lots of people arrive on Friday and leave early on Sunday. The camping fee is now $10 which includes the ramp fee at this Corps of Engineers facility. There is no schedule of events. We have a pitch in dinner on Saturday evening.
A Toto nears completion built by Barry and Thomas Johnson.
SAIL AREA MATH
BACKGROUND...I have to rerun this article every year because boaters tinker with their sail rigs and some pencil scratching early will save you a lot of head scratching later. In general your sail area has to center on a certain place in order for your boat to handle right. If you are substituting one sail for another you need to do this math work to get it in the ballpark. Even if you have a factory boat you might find it doesn't handle as well as it could. This essay may give you some guidance about what you can do to improve things.
THREE SIDED SAILS...
FOUR SIDED SAILS...
Another way is to dangle the cutout on a pin stuck through a corner and into a wall marked with a vertical line that passes through the pin point. Mark the line that passes through that pivot corner and a vertical. Then rotate the cutout to hang it from another corner, and mark a second line through the second pivot corner and a vertical. The centroid lies at the intersection of those two lines. Back at the missile factory the designers had a favorite place, complete with pivot pin socket hole and vertical line, to hang these cutouts and that place was known as the "weighing wall". Meanwhile the super computer cranked away next door but its answers weren't to be trusted unless they agreed with the cutout hanging at the weighing wall.
RIGS WITH MANY SAILS...
I'll discuss making sails from polytarp.
Campjon
CAMPJON, CUDDY JONBOAT, 15.5' X 5', 300 POUNDS EMPTY
Campjon is based on my Jonsboat design. I increased the hull depth to 24" from 18" and again to 30" in the region of the 6' long cuddy cabin. The cabin decks slope upward towards the center so the "headroom" in the middle is about 3', usually that is enough to allow sitting up while seated on the floor. There is a slotted walkway on the cabin centerline just like I've used on my AF sharpies, but this one also has a step through to the front deck. The front deck itself is fairly large and easier to use as a boarding platform than with the AF sharpies. But it is very important to NEVER let anyone ride on a front deck like this when the boat is in motion. If they slip off the deck they have no option but to slide under the boat full length and through the prop in an instant.
The prototype Campjon was built by Luke Spreadborough in Queensland Australia. Here he is using a 2.5hp motor.
I doubt if the increased freeboard makes the boat any safer since a flat boat like this is not good in rough water in any case. The higher sides do give a feeling of greater security since this will be a boat you are "in" instead of "on". This would be a better family boat since the kids can be kept cornered in the cuddy while underway. They can stand in the slot, or look out the front or out the windows. I suspect the cuddy will find a lot more use as a spot for the portapotti than as a camping cabin. The cockpit as drawn has no seats and is itself a big playpen. For seating I suggest using common folding chairs like I have used with satisfaction on my AF4. When the boat is not underway the chairs are folded and stowed, or relocated to another part of the boat or the shore.
As for power I would suggest a good 15 hp motor or a 10hp to keep the capability of using the smaller lakes which are wisely limited to 10 hp. With 10hp and with two normal sized adults the boat should plane, and be very lively with one aboard. But I've noticed with my own AF4 that weight gets added as time goes by and I've noticed that folks usually build their boats heavier than I do. I should add that the Coast Guard has suggestions about powering small boats and they come down hard on flat bottomed hard chine boats like jonboats because of handling concerns. I think they would advise a max of 25 hp in a hull like this. (My AF4, which is about the same weight as Campjon, went 22mph with a 40 year old Johnson 18. Greg Rinaca's Jonsboat went 26mph with 18hp.) There is a draining motor well in the stern.
Constuction is nail and glue, with no jigs or lofting. From four sheets of 1/4" plywood, two sheets of 3/8" plywood, and two sheets of 1/2" plywood.
Plans for Campjon are $30.
The Florida Shanteuse just needs windows and top paint. Remember, this one stretched from 16' to 24', a big boat on a big trailer.
