(1may02) This issue will discuss butt joints in plywood sheets. The 15may02 issue will present an essay about building the HC Skiff.
NOTE, 26APR02, THE DUCKWORKS MANAGER IS ON VACATION FOR A FEW WEEKS RIGHT NOW AND IT IS NOT CLEAR TO ME AT ALL HOW THE PAYPAL ORDERS ARE BEING HANDLED! SO UNTIL FURTHER NOTICE (WHEN CHUCK GETS BACK FROM VACATION) I'D GREATLY APPRECIATE IT IF YOU DID NOT ORDER THROUGH PAYPAL. YOU CAN USE THE ONLINE CATALOG TO MAKE A CHOICE, THEN SEND YOUR ORDER TO ME BY SNAILMAIL AND PAY WITH A CHECK, REDUCING THE DUCKWORKS CATALOG PLANS PRICES BY $6.
THE KEYSTONE MESSABOUT, at Keystone Lake, Oklahoma, will take place May 11-12. Click here for details.
THE 13th ANNUAL MIDWEST HOMEBUILT BOAT MESSABOUT will take place on June 8 and 9 at the Gun Creek Recreation Area at Rend Lake in Southern Illinois. Take exit 77W off I-57, head towards the golf course and you will see the signs. Lots of people arrive on Friday and leave early on Sunday. The camping fee is now $10 which includes the ramp fee at this Corps of Engineers facility. There is no schedule of events. We have a pitch in dinner on Saturday evening.
THE LAKE CONROE (HOUSTON, TEXAS) MESSABOUT of April 13 was a big success. Look at a report with lots of good photos at Shortypen's boat page
Bob Williams' IMB at the Houston Messabout.
JOINING PLYWOOD SHEETS
BACKGROUND...Almost any boat you build from plywood will require panels longer than the 8' lengths you will find at the lumberyard. For an "instant boat" the usual manner of joining the panels together to get one long panel is with a butt strap or butt plate. I've tried lots of different ways to make the joint in the 15 or so boats I've built over the years. All the methods worked. I have a feeling that the butt joints on the usual instant boat hull are not highly loaded and not too critical to overall boat strength. Since I've tried several ways and they all worked I've gotten to be pretty nebulous about the subject on my drawings. Lately I've been specifiying a butt plate as something like "Butt plate from 3/4" x 3-1/2" lumber, or equal" which doesn't tell you much. Most builders get by pretty well with just that but recently one builder asked what in the world I meant, and rightly so. So let's start the discussion with one joint I've never tried in plywood.
What good about it? The faces are smooth both sides. Essentially you have a single piece of wood to work with after making the joint. It's quite strong, as strong as the base wood provided the taper is long enough. I've seen the taper range from 6:1 to 12:1. The shorter tapers are easier to make and probably just as good given modern glues.
THE PAYSON TEAL BUTT STRAP...
THE BIRDWATCHER BUTT STRAP...
THE LUMBER BUTT PLATE...
This is I like to advise now. Not much to it. Very quick and easy to make. Some say it looks too clunky for their tastes.
If there has been any structural problem with the above butt plate it is at the ends of a plate that joins bottom panels, ending short of the sides to allow a limber path. If the ends of the plate are not solidly glued and fastened to the bottom panels the butt plate will eventually loosen at the ends. I think that is due to the rapid change in flexibility in the system where the plate suddenly ends. A better solution might be to taper the end of the bottom butt plates starting maybe 3" in from the end of the plate and tapering down to maybe 3/8" thick at the ends. That will allow a gradual change in the flexibility and prevent a stress riser at the end of the butt plate. By the way, for any bulky butt joint care must be taken in design to see that the joints don't fall in places where the butt plate will be in the way.
I'll present a builder's essay about making the HC SKiff.
IMB
IMB, SAIL BEACHBOAT, 13-1/2' X 5-1/2', 350 POUNDS EMPTY
The prototype IMB was built by Jerry Scott of Cleveland, Texas. (This boat was originally drawn for a design competition sponsored by International Marine Publishing a while back and was called the International Marine Beacher, or IMB. I didn't win anything (again).) A second IMB was completed recently by Bob Williams, also in Texas.
IMB features a "Birdwatcher" cabin. Birdwatcher cabins are full length with panoramic watertight windows and a center walkway slot in the roof. Everyone rides inside including the skipper.
Around 1984 Phil Bolger showed me a cartoon of his 24' Birdwatcher and I didn't know what to think of it. He presented it in a 1986 issue of the old Small Boat Journal. Ron Mueller built the prototype and convinced me that this cabin really works. I built the second Birdwatcher and here is what I found:
These boats can be self righting without ballast because the crew weight works as ballast. They sit down low on the floor looking out through the windows (although I found standing in normal winds was quite acceptable). In addition, the high cabin sides provide lots of buoyancy up high to ensure a good range of stability. IMB, which is small and has no ballast, will probably self right from 60 or 70 degrees of heel, but the larger ones such as the water ballasted Scram will self right from a full 90 degrees knockdown. Others like the original Birdwatcher and my Jewelbox have 1" thick bottoms which give enough weight down low that they self right from a "windows in the water" knockdown. Here is a photo of the inside of Bob's IMB:
These boats can be operated totally from within the cabin, like an automobile. No one need ever go on deck. For boating with children I can see no equal.
These are cool boats. The tinted Plexiglass windows cut the sun's power. The crew can always sit in the shade of the deck. Downdraft from the sail cascades through the walkway slot.
IMB has an 8' long cabin on a wide multichine hull, sort of an enlarged Piccup Pram hull.
I haven't really gotten a test report of this boat yet but the photo above taken on its first sail shows to me that it must be pretty close to "right". I did get a report from Bill Paxton who attended the Houston meet and filed this report:
"All right, I admit it. When it comes to sailboats, I'm a size bigot. Or at least I was until I took a ride in Bob Williams' IMB.
"I truly like the idea of Jim Michalak's "birdwatcher" designs. These clever craft provide comfort and safety in boats that are easily built by any novice. I've spent a lot of time studying JM's Jewelbox. At 19' it's the largest of its type in Jim's repertoire. With a 12' cabin, it could host a whole Cub Scout Pack. It's a little large for my needs so I found myself pouring over Jim's Jewelbox Jr., a 16' version with an 8' cabin. Nice. Scram Pram and even Eisbox were considerations. But at no time did I seriously consider the IMB. Why? It's too short! How can a cabin sailboat with a length of 13.5' be taken seriously?
"Man, was I ever wrong!
"I met Bob Williams at the Lake Conroe Messabout, and I was immediately fixated on his new IMB. He patiently answered all my questions, and then, generous soul that he is, agreed to take me along with him and Bob Shipman for a ride. (You'd be hard pressed to find two finer sailing companions than the Bobs.)
"The first thing that impressed me was the volume of space in the cabin. It' s 8' long. The three of us had plenty of space to sprawl out, and at no time did I feel like we were getting in each other's way. Skipper Bob mentioned that he had slept in the cabin Friday night, and said it was downright spacious.
"A real surprise was the ease with which we could carry on a conversation inside the cabin. The sound bounced around nicely making it effortless to hear one another.
"The breeze was gusty and unreliable. At times we were really flying along, and at other times we drifted from puff to puff. This gave me a chance to see if the cabin would heat up. It got a degree or two warmer than the 80 degree outside temperature, but that was about all. When making any decent speed at all there was a fair amount of breeze through the cabin.
"I enjoyed sitting in the shade as we sailed along. With the large slot top down the middle it's impossible to stay in the shade all day on all tacks, but it's way more solar protection than I get in the open cockpit of my boat. I also like the idea of being able to stand up and stretch while under sail.
"One of the things I was curious about was visibility. Would we really be able to see well enough looking out the windows? The answer is yes. I never felt we were in danger of other boats we failed to see. But there's always the option to sit on the aft deck, steer with your knees and swivel your head to your heart's content.
"Under the aft and fore decks are storage areas large enough to hold camping supplies for one man for many days.
"Did I mention how easily the boat handled choppy water? Oh sure, the wake from large powerboats tended to kill our speed when we hit them head on. But the multi-chine hull gives the boat "soft shoulders," and it never felt like we were in any danger of being pushed over.
"Jim Michalak did a great job designing a boat that seems bigger on the inside than on the outside. Bob Williams did a fine job of building his IMB, Happy Camper, and I'm glad he brought it to Conroe. It sure taught me a thing or two."
IMB takes two sheets of 1/2" plywood, 8 sheets of 1/4" plywood and one sheet of 3/16" dark tinted Plexiglass. Taped seam construction using no jigs or lofting. Sail is 104 square foot balanced lug with pivoting leeboard.
Plans for IMB are $30.
The Queensland Campjon is about done. Waiting for a trailer.
A barn in rural Florida giving birth to the first Shanteuse, this one stretched from 16' to 24'. The builder said it was easy to turn the hull but it looks like his name is John Deere.
