This issue will continue about knockdown recovery. The 15 november issue will rerun an issue about rigging a balanced lugsail.
THE BOOK IS OUT! BOATBUILDING FOR BEGINNERS (AND BEYOND) is out now, written by me and edited by Garth Battista of Breakaway Books. You might find it at your bookstore. If not check it out at the....
Bill Turnbull & Co. get their Toto ready for a dip on the Gulf Coast.
KNOCKDOWN RECOVERY3
WE CAPSIZE IMB....
Special thanks to Shorty Pen who supplied these photos. Click over to his site to see a lot more of the Conroe messabout.
I was very fortunate to be able to attend the Lake Conroe (Houston) messabout on 28Sep this year. Among all the attractions were two IMB's! They are the only ones I know of. The first was built by Gerry Scott and the second by Bob Williams (77 years young I'm told and totally up to rigging and using the boat solo).
Here is what we did. TheIMB was beached and we removed the trolling motor and battery and all the loose things. The boat was walked into waist deep water, parallel to the shore, and human anchors placed at bow and stern. The halyard was secured to the mast and its free end given to me close to the shore. So I could pull the boat over with the halyard while the good folks held the boat in place.
Repeating the test was quick and simple although the effort to haul it over was quite a bit greater with Gerry's ballast inside. We pulled her over slowly to make sure Gerry had time to brace himself as required. Look closely and you can see him hanging on to the mast with one hand and waving to the camera with the other hand, something he would not be doing in a real capsize.
You might image what being inside would be like, and I'm thinking of that old Fred Astaire film where he dances in a rotating room the final affect being that he goes from dancing on the floor then on to the walls and then for a stint at dancing upside down on the ceiling. ![]()
We'll take another look at rigging a lugsail.
IMB
IMB has an 8' long cabin on a multichine pram hull. The prototype was built to perfection by Gerry Scott of Cleveland, Texas. At the Conroe (Houston) messabout I got a chance to look over his boat plus the only other IMB I know of built by Bob Williams. Both boats were quite true to the plans. Both had added low inside seats which made them more pleasant to use to the point that I will show some seats on the plans. I was worried when I drew IMB that the headroom would be minimal so drew no seats thinking the crew would sit on the floor, as with the original Birdwatcher. While I was sailing with Gerry, Bob's boat came out on the lake with four adult males and no sign of bogging down, showing that these fat pram shapes, very much like my Piccup Pram, can handle a lot of weight in the 13.5' length. Here are three of the pirates plus another who was taking the picture.
Later they took on a mermaid and returned to the dock with five.
Both men adjust well to the lug sail/leeboard rig. Gerry's has the blueprint 104 square foot sail and Bob's uses the 114 square foot Bolger Windsprint sail available from Payson. I used to worry a bit about running a leeboard on a full cabin boat like this since handling must be done by remote control, so to speak. No problem. Both boats have the leeboard lanyard running to a cleat on the aft deck. The leeboard position is plainly in view at all times through the cabin window. In use these leeboards need only lanyards to pull them down. Once down they will usually stay down until they strike something. Then they pop up and you will need to pull them down again. I've never seen a need for a lanyard to pull the board up although I've seen several rigged that way. The Dovekie design had elaborate cam operated levers in the cabin that operated the leeboards and I thought that all very clever. But in talking to some Dovekie owners I found the internal levers are not universally loved since they can often be in the way. Anyway, my idea was not to run the down lanyard to the aft deck but rather through a small hole in the side of the boat, say 1/2" for a 1/4" lanyard, so it could be operated totally from inside the cabin.
IMB plans are $30.
Sowsear: I'm told the Pennsylvania Sowsear is finished and has been tested. Should have photos soon.
An Australian buider has started a Dorado which is a power version of Frolic2. At the point of looking like a boat....
