(15apr03) In this issue we'll talk about setting up a rowing boat. The 1May issue will be about measuring propellor "slip".
THE 14TH MIDWEST HOMEBUILT BOAT MESSABOUT will take place at Rend Lake in Southern Illinois on the weekend of June 7 and 8. Lots of folks come on Friday and leave early Sunday. Take I-57 to exit 77W and then follow the signs to the Gun Creek Recreation Area. Camping at this Corps of Engineers facility is $10/night and that includes the ramp fee. There is no schedule of events except a pot luck dinner in the campground on Saturday evening- we wing it. This year some of us have reserved the campsites on the water of the two middle camping loops so look for us there if we aren't at the boat ramp.
Max Wawrzyniak in his new Oracle.
ROWBOAT SETUP
NEXT TIME: We'll measure propellor slip.
ORACLE
The Australian Twang builder is done and is testing, searching for the ideal seating position.
The Alabama Skat is getting its seams taped.
A Piragua18 is being completed in Georgia:
