(15Jun03) In this issue we will rerun the all important sail area math topic. The 1july issue will recap the events at the Midwest Homebuilt Boat Messabout at Rend Lake.
Greg Rinaca uses this new Roar2 for exercise down in Texas.
Sail Area Math
BACKGROUND...I have to rerun this essay every year. This subject is the most common area where tinkerers of designs get in trouble. It always has been and always will be. Anytime you modify the sail rig you need to keep this math in mind.
THREE SIDED SAILS...
FOUR SIDED SAILS...
RIGS WITH MANY SAILS...
...We'll look at the last Midwest Messabout at Rend Lake.
Ladybug
Ladybug is a lot like Woobo which was one of my first designs. There was a Woobo near here for a while. I never got to sail it but was told it would really fly. (That boat was made of Lauan plywood from Home Depot which fell to pieces after rainwater filled the boat over the winter.) Ladybug is a bit shorter and wider and deeper and has bench seating, much more suited for older legs. Both boats have a small motor well. The best motor for something like this is the 2hp Johnson/Evinrude which weighs 25 pounds. Even that is overkill since 1hp will push this hull at top speed, anything more just makes bigger waves.
Ladybug uses taped seam construction. Six sheets of 1/4" plywood, on sheet of 3/8" plywood and two sheets of 1/2' plywood.
Prototype plans for Ladybug are $25 until one is built and tested.
The Alabama Skat now looks very boatlike:
A Piragua18 is completed in Georgia. I hope to have a writeup in a few weeks.
This Seal Cove Skiff was completed a while back, built within a few weeks of when the plans were released. There was a delay in launch until the Canadian ice melted. Write up soon.
We've already got a Ladybug builder down in Texas:
