(15May03) In this issue we will rerun the article about taping seams. The 1Jun issue will show fuel consumption tests with old outboards.
THE 14TH ANNUAL MIDWEST HOMEBUILT BOAT MESSABOUT will take place at Rend Lake in Southern Illinois on the weekend of June 7 and 8. Lots of folks come on Friday and leave early Sunday. Take I-57 to exit 77W and then follow the signs to the Gun Creek Recreation Area. Camping at this Corps of Engineers facility is $10/night and that includes the ramp fee. There is no schedule of events except a pot luck dinner in the campground on Saturday evening- we wing it. This year some of us have reserved the campsites on the water of the two middle camping loops so look for us there if we aren't at the boat ramp.
Bayard Cook flips his AF4 project.
Taped Seams
My own taped seam history started about 1985. I made a Payson/Bolger dory with taped seams even though it was originally designed to be made on a ladder frame with chine logs in the old fashioned way. Payson's book "Build Your Own Boat" had the complete dory plans and also included the side panel expansions! It was easy to build a taped seam version with no ladder frame. Harold used polyester resin in his projects probably for the same reason others have used it - it's cheap and available. So I used it too on that dory. I tried ordinary automotive Bondo to fillet the seams instead of the resin/filler mixes that Payson advised. That boat had but one layer of glass inside and out. I used it for about five years until it got crushed by another boat in a tornado. The transom tapes were ripped (but the polyester resin held), and the boat was sort of opened wide. I gave it to Jim Huxford who repaired it and rowed it. In many ways my boat Sportdory is a rework of that old dory. (Jim Huxford, a great boatman who attended all of our early messabouts, passed away last autumn.)
"What's with all the polyester resin and Bondo?" you ask. Anyone who mentions using these in the rec boatbuilding newsgroup gets pounded and made fun of. Even 15 years ago Payson was attacked for building with polyester. I didn't know any better and have really had no major troubles. Whenever I use one of my polyester boats I tell it, "You'd better start falling apart soon. You're making those experts look bad and they are going to pound me on the newsgroup and make fun of me." So far my boats haven't listened.
Polyester has certainly worked OK for me. My boats are stored under cover as a rule (although some have been outdoors for months at a time). That is I'm certain a factor in their longevity with polyester. I think when we started 20 years ago we got polyester for $13 a gallon (good stuff too) while epoxy went for about $70 a gallon. Now we know where to get much cheaper epoxy. So now I advise epoxy.
THE INNER SEAMS... ![]()
TAPING THE OUTER SEAMS....
FINAL WORK...
YOU'RE DONE!
NEXT TIME: Rev up some old outboards to see how much fuel they drink (a lot).
Larsboat
I also drew up a trimaran sailing rig for Larsboat called "Trilars" which is sold separately for $10.
It is pretty much a clamp on rig except for the small mast step and partner. To date no Trilars has been built that I know of. But down in Texas Charles Nichols built a model of it:
It's different from the Trilars. The main hull is per the Larsboat blueprint but built without the deck. I thought the rudder and leeboard were just like the Trilars print. The sail is a large balanced lug instead of a sharpie sprit. The floats are triangular in cross section instead of flat bottomed as on the Trilars, and I'm pretty sure the Charlars is wider than the Trilars which I drew narrow enough to trailer without disassembly. There wasn't much wind that day but I got a little sailing in with the Charlars and it seemed fine with the potential of being wicked fast. My only thought was that it was fast and stable enough (it was stable as a dock) that in rough water it might spear a wave and ought to have the fuller deck, something I think the paddling Larsboat can get by without in most cases.
The Alabama Skat now looks very boatlike:
A Piragua18 is being completed in Georgia. (This boat is done and tested but I'm hoping for a good "in the water" photo.)
This dog contemplates its new house. Oh Canada!
