(1Dec03) This issue willl repeat the essay about the IMB self righting test. The 15dec03 issue will update messing with motors.
David Davis rolls his Picara project, tires ready and cat making room.
IMB Capsize Test
WE CAPSIZE IMB....
I was very fortunate to be able to attend the Lake Conroe (Houston) messabout. Among all the attractions were two IMB's! They are the only ones I know of. The first was built by Gerry Scott and the second by Bob Williams.
Here is what we did. The IMB was beached and we removed the trolling motor and battery and all the loose things. The boat was walked into waist deep water, parallel to the shore, and human anchors placed at bow and stern. The halyard was secured to the mast and its free end given to me close to the shore. So I could pull the boat over with the halyard while the good folks held the boat in place.
Repeating the test was quick and simple although the effort to haul it over was quite a bit greater with Gerry's ballast inside. We pulled her over slowly to make sure Gerry had time to brace himself as required. You might image what being inside would be like, and I'm thinking of that old Fred Astaire film where he dances in a rotating room the final affect being that he goes from dancing on the floor then on to the walls and then for a stint at dancing upside down on the ceiling. Anyway, here is the scene close to 90 degrees with Gerry smiling and waving to the crowd, something he might not do in a real capsize.
...we mess with motors in 2003.
IMB
IMB plans are $30.
The Texas Ladybug gets painted:
The Tennessee Shanteuse is rightside up now on a trailer:
Out West the Picara project gets its bottom. Winter approaches:
Another Picara, this one with a 1' stretch in the middle, going together in Arkansas.
