(1Sep03) This issue will give thoughts about measuring propeller thrust. The 15Sep02 issue will present a rot repair not approved by Woodenboat.
The 12th ANNUAL INDIANA MESSABOUT will take place at Lake Monroe (just south of Bloomington) on September 19 thru the 21st. All at the Paynetown Recreation Area. For more info contact Bob Bringle at rbringle@iupui.edu.
Barry Johnson and company with a new Jonsboat.
Measuring Prop Thrust
"THE MOST SIGNIFICANT NEGATIVE EXPERIMENT IN THE HISTORY OF SCIENCE"!!!![]()
Before I get started talking about propeller thrust I want to set the stage with a dedication to Albert Michelson who spent his life measuring the speed of light. Born in Poland, his family came to the US when he was a little boy. He became expert with optics. In the mid 1800's the speed of light was known in a general way and Michelson, along with his helper Morely, made a device that would measure the speed of light to a degree of accuracy never known before. In fact they thought it so fine as to measure the effect of the earth's orbital movement on the speed of light according to the "ether" theory of light propogation that was current at that time. So they measured and measured and measured. They did indeed zero in on the speed of light but saw no orbit effects. The speed of light was the same no matter how it was measured. Michelson had enough confidence in himself that he published the results even though there was no explanation to be had. That was in 1883. Then in 1905 along comes young Albert Einstein who knows about Michelson's results. Einstein doesn't really explain it except maybe to say "accept it because that is the way it has been proven. The speed of light is always the same no matter how you measure it." And with that basis Einstein went on to figure his theory of relativitly and the rest is history. So just because you can't explain something you measured doesn't mean it is wrong.
NEXT...
PROPELLOR THRUST....
SO I MAKE A THRUSTOMETER...
DOES IT REALLY WORK?????
...I'll show a rot repair that is not approved by Woodenboat.
MAYFLY12
MAYFLY12, ROW/SAIL SKIFF, 12' X 4', 120 POUNDS EMPTY
Mayfly12 is a small general purpose row/sail skiff based on the lines of the traditional flat iron skiffs of 100 years ago. By that I mean she has a nearly vertical stem, flaring sides from the midsection to the stern, and a raking stern. And she has quite a bit of rocker as did the originals. Mayfly12 is made from two sheets of 1/4" plywood and two sheets of 3/8" plywood. The heavier plywood is used to make a stiff bottom although one might save 20 pounds by using 1/4" plywood all over. I think the popularity of 12' skiffs is that they are usually all that one can cartop solo. Beyond that size and you should use a trailer. Once you have decided to get a trailer you might as well go to a 16' boat which is usually the most boat one can manhandle solo in the water. Sailboats larger than 16' are getting out of the "impulse" catagory and you should do some serious thinking before building one. Lightweight and simple boats like canoes and rowboats can be cartopped successfully at almost any length provided they weigh less than 100 pounds.
Here is the prototype boat by Mike Cerio in New York. There were at least two other Mayfly12's built but I did not get this short of photo so kept carrying the boat as a prototype. One of those boats was built with a daggerboard in lieu of the leeboard and it sailed quite well. This might have been Mike's first boat, certainly not his last:
I've kept the sharpie sprit sail that might have been found on a traditional skiff 100 years ago. It requires no store bought fittings to work well and its simplicity means it will work well most of the time. Its only real drawback is the 16' mast it requires. Unlike the traditional boats, I have used my favorite pivoting leeboard and kickup rudder so you can sail in shallows with no fear. And this boat has buoyancy/storage boxes fore and aft to allow self rescue of a capsized boat. By the way, to reboard a boat like this after capsize you usally need to scoop some water out of the cockpit before trying to climb back into the boat, and you usally must reboard over the stern. These boats are often too light to accept the weight of a man trying to climb over the side without capsizing again. The bailing is needed to rid the boat of water sloshing from side to side causing an uncontolled roll that might lead to another capsize.
Plans for Mayfly12 are $25. No jigs or lofting required. Uses old style glue and nail construction for the most part, but has taped seams on the side/bottom joint.
The Alabama Skat is in the paint stage:
The Texas Ladybug is starting to look pretty roomy:
Am upside down plywood box I'm told is the true 16' Shanteuse (at last) is going together in Tennessee.
The Colorado Trilars looks ready to go:
Also there is an Otter (long narrow rowing boat patterned after the Pete Culler Otter) nearly done in New York. Builder is making special oars now.
