(15Jan04) This issue will melt some lead for sink weights. The 1Feb04 issue will rerun the lugsail rigging essay.
Bob Goad's well worn Mobydink, great homemade oars.
Making Sink Weights
WHY SINK WEIGHTS????....
MELTING THE LEAD...
This is Tidmarsh's setup.
...we look at rigging a lugsail.
Shanteuse
There was a Shanteuse built in Florida by Vince SantaMaria a couple of years back but he stretched his to 24' so I couldn't really call that one a Shanteuse. But here is one by Douglas Snelson in Tennessee that looks to be right to the plans so I will call this one the prototype. He sent a bunch of photos:
As for operation, these are smooth water boats. So it is best to stay on small waters that never get too rough. On bigger waters you need to watch the weather very carefully. For power I would stick to 5 or 10 hp but I'm very much a chicken about these things.
Plans for Shanteuse are $35.
Out West the Picara project gets its bottom. Winter approaches:
Another Picara, this one with a 1' stretch in the middle, going together in Arkansas.
