(15May04) This issue will show how to set up a rowing boat. The 1Jun04 issue will discuss putting motors on rowing and sailing boats.
THE 15TH MIDWEST HOMEBUILT BOAT MESSABOUT will take place at Rend Lake in Southern Illinois on the weekend of June 12 and 13. Remember that lots of folks come on Friday and leave early Sunday. Take I-57 to exit 77W and then follow the signs to the Gun Creek Recreation Area. Camping at this Corps of Engineers facility is $10/night and that includes the ramp fee. There is no schedule of events except a pot luck dinner in the campground on Saturday evening - we wing it. This year some of us have reserved the campsites on the water of the two middle camping loops so look for us there if we aren't at the boat ramp.
ROWBOAT SETUP
Next the boat was placed in the water tied loosely to the dock. Max climbed in and we looked for the seating position that would provide a level boat.
NEXT TIME: We'll take a look at putting motors on rowing and sailing boats.
Vireo14
Vireo15 plans are $15 when ordered direct by mail from me until a prototype is built and tested.
The Texas Ladybug is looking about done:
Out West the Picara picks up where it left off before the winter:
The Deep South Skat is getting its brightwork:
Another Picara, this one with a 1' stretch in the middle, going together in Arkansas. Sailmaking done and its on to glassing the hull.
This is an AF4Grande (upside down):
