(15Oct04) This issue will rerun the capsize recovery essay. The 1Nov issue will be about more capsize recovery.
Knockdown Recovery
And now on to our story...
AF3 CAPSIZE RECOVERY...
"Hi Jim:
"I do not know because we were not sailing it at the time. We were both standing on the cuddy deck fiddeling with the sail in a good blow and it went over real fast. We have regularly sailed the hull at up to 20 degrees of heel and it does not feel unstable although I like it best at 10 degrees of heal. I have an inclinometer on the boat (overkill I know) so I know that the angle of heel is a real measurement not a guess. When sailing I had one puff that almost caused a knockdown because I had accidently cleated the main sheet. What happened is the boat healed over dramatically and the sail depowered enough that equilibrium was reached and I was able to uncleat the sheet in time to prevent a capsize. Unfortuantly I did not look at the inclinometer, but I was busy at the time.
"I climbed on from the stern. I have a small step on the stern that also doubles as a support for my mast cradle. I put my hands on the stern deck and placed my foot on the step and climbed on board. I must take a photo of this step and send it to you. With the step it was easy to reboard and I could walk around in the cockpit with the water in it and bail it out. Gord then reboarded over the side, which was much more difficult and his choice not mine."
At summer's end he wrote:
"Hello Jim:
Herb"
...More capsize stuff.
Imresboat
IMRESBOAT, DOUBLE PADDLE CANOE, 15.5' X 26", 50 POUNDS EMPTY
Imresboat is a slimmed up version of Larsboat which was designed for Lars Hasselgren to replace a Folboat that had finally met its end. Lars wanted capacity for two, plus decking, as with his old Folboat. But Imre wanted something more slender and lower in the same length. The result is 26" wide instead of 30" wide. And the result of that is that Imresboat is a single seater because the capacity has been reduced with the width. Imre wanted it even narrower but I hoped to stay within the tippyness bounds of most folks. Not sure yet how narrow something like this can get before the normal guy can't sit upright in it. I do know that you apparently can get used to about anything in that respect as experienced kayakers do.
The deck opening is smaller to sit just one man but I think it is longer than the usual kayak because us older folks have trouble fitting our legs through the hole in a performance kayak. Something like putting on a pair of pants without standing up.
(Here is a photo of Paul Moffitt's Larsboat with two aboard.)
Another change I made with Imresboat is to go to thinner plywood to save weight. In this case I suggest 1/8" ply for everything except the bottom which is still 1/4". Not sure where the 1/8" plywood comes from but it used to be what they skinned doors with. Be sure to boil a sample and hope it is waterproof. Anyway, Chuck Leinweber brought a Toto to our messabout with 1/8" ply sides and 1/4" bottom and it struck me as being fine for stiffness and strength. Like Toto and Larsboat, Imresboat is taped seam construction. I'm guessing at the 50 pound weight but for example Larsboats built of 1/4" plywood have weighed between 60 and 80 pounds depending on who built them.
Imresboat plans are $20 until one is built and tested.
The 30' Cormorant has been flipped! Bottom totally painted so there should be no upside down work to do. Read about the flipping at www.breakawaybooks.com/Flipping_Cormorant.htm
The out West Picara is rightside up now waiting for its roof:
