(1Dec04) This issue will start a guest essay about scarf joints. The 15Dec issue will finish the guest scarf essay.
Scarf Joints 1
Remember Rob Rhode-Szudy? If you met him at the 2002 Rend Lake Messabout you would not have forgotten him. Here he takes his family for a sail in his 11' Piccup Pram:
Rob is building again and sent this article for all of us to read:
SCARPH JOINTS THE EASY(ISH) WAY
So, you want to build that bigger boat, but then you see the part of the plans where you need a 25 foot 2x2 for each gunwale. Egad! Scarph joints!
Yes, friend, you're gonna have to delve into the magical netherworld of "real" woodworking inhabited only by trolls, gnomes and writers for WoodenBoat.
Well, the woodbutchers just crashed their party. Let me show you how.
The "bigger boat" I mention above is a Bolger Light Schooner, and it does indeed require 25' 2x2s for the sheer clamps, as well as several other long pieces of 1x stock. Just to make it harder, I had a whole bunch of really nice, old, straight, clear white pine that used to be the porch floor of the house where I grew up. Of course, the pieces were only 7 feet long! I made several poor attempts at scarphing before I found something I could do reliably.
BANDSAW SCARPH
This was my first attempt. I cut a wedge "template" and masking-taped it to the side of the stock where I wanted to cut the scarph. Then I set up the bandsaw's rip fence and put the template side against the rip fence. Sloooooooooow going on a bandsaw. Snapped a blade. My dust mask did little to save my sinuses from the tons of ultra-fine sawdust I made. Smoke too! It doesn't matter how thin it is sideways. It's the top-to-bottom dimension that the saw hates. This, by the way, is a REAL bandsaw. A big, old, cast iron Delta. It might have been short work with the right blade, but the accuracy was the real problem. A thin blade like that wanders in a tall cut, and my chines will thus have gaps with lots of Weldwood and little wood.
In fact it is worse than that. There are some gaps with no wood OR Weldwood! I should have used epoxy or PL400 on those poor fitting scarphs. I had to nail them just to hold them together when bending the sides around the bulkheads, and they formed weak spots in the curve that needed to be pulled in with a Spanish windlass. That was a big pain in the butt and waste of time. Being too late to make new chines, I will have to add a strip of plywood to the inside of the chine after the bottom is on, well nailed and glued, to strengthen this mess.
Here's a photo of what they looked like before ripping them into chines. You'd think I'd have noticed, eh?
I did the deck carlings the same way and snapped one while dry fitting it. Of course, it was only then that I realized the carlings can be butt joined with a plywood gusset inside the center compartment. This is how I'm doing it now. Sometimes it takes a while for that dim bulb upstairs to warm up. I comfort myself that Bolger didn't think to show that method in the plans either.
On to happier attempts!
TABLE SAW SCARPH
Same deal as the bandsaw scarph, but less wander and MUCH more smoke! The blade was new too! I also had to remove the guard to run 3" high stock through this saw (it's the cheapest of the Craftsman line), and frankly that scares me. I like my fingers right where they are, thanks!
OK, so that wasn't a MUCH happier attempt, but I'm much happier that I didn't waste a lot of time on it.
OLD SCHOOL
Well, sometimes the old school way is actually faster. I decided I needed a truly reliable guide for depth. I nailed the stock to a piece of plywood - all of the joints lined up. I made sure the ends were in line with each other and square. Then I drew lines across the boards 1" from the end, and 2", and 3"…on up to 18". (That's 18" in the 2x and 9" in the 1x.)
Then I pulled out that wedge template I had made and drew the same marks on it, and lined it up so it was right where I wanted the scarph. I could have struck a line from it onto the side of the stock, but I had something better in mind. (You'll see in the photos that I did strike the line anyhow, just as a double check that I wasn't getting too far off.)
I UNPLUGGED the circular saw, then retracted blade all the way. Then I set it on the stock with blade alongside the stock, placed it so the lowest tooth lined up with the 17" mark. (That is, the line perpendicular to the stock, 17" from the end.) Then I lowered the blade until it just touched the wedge. Remember that the wedge is lined up right where the scarph should go, so it provides a depth gauge for the saw to cross-cut a guide kerf. That, in fact, is the next step. I locked the blade, pulled the wedge out of the way and cut a kerf on the 17" line. I repeated the same process for all the lines, all the way down the wedge.
The bottoms of the resulting kerf outlined the top of my scarph! The only remaining job was to remove the waste. This is not nearly as hard as it seems. Almost pleasant, in fact. Makes you feel like a REAAAAAL wooden boat guy, too.
CHISEL WORK
Yeah, you have to use a real woodworking tool. Scared me too. It doesn't need to be an expensive one. Mine was a garden variety hardware store 3/4" chisel. Look for a long blade and a long handle, though. The stubby ones won't give you enough working space. Of course "real" woodworking chisels work fine for this, but there's no need to spend $40 for merely roughing out a scarph.
The first step is to split out the bulk of the waste from the end. Don't try to go right down to the line. On each "step", first take off like the top 1/4", then cut in maybe 1/8" intervals down to about 1/8" above the kerf. The sharper your chisel is, the closer you can cut to the line without having the grain take control of the cut.
Speaking of which, cheap folks like us don't get wood with vertical grain. No problem. Keep the blade 90 degrees to the grain, whatever it is. I found that in this "splitting" direction, the grain is boss. It wants to split more than cut. Actually it cut fine for the first few whacks, but then started to get dull and acted more like splitting. So you'd best plan for splitting. If you do that, it will always work. If you plan for cutting, it'll ruin your day when it splits. Remember, in this first pass, just get it sort of close. Maybe 1/8" from the line - 1/16" at the absolute closest. It should still look like steps, and you should still see the kerfs.
Now some of you will wonder why I didn't chop out the waste from the side so I could see the depth. Well, I did the first one that way and found that it dulled my lousy sharpening job on my lousy chisel almost immediately. "Splitting" it out made the chisel last longer, or at least made the edge not really matter.
Now smooth these "steps" down a bit more in the opposite direction. Sharpen the chisel first! More on how to do this a bit later. Hold the chisel almost flat to the stock. It's OK if you chisel a bit too flat, but you don't want to dig in too deep. Be especially careful if the grain is trying to "help" the blade dive in - that would be a very good time to cut across the plank instead. When you're done with this step you should still see most of the kerfs, but they will be very shallow.
Now some of you will ask why I didn't use a jack plane for this. Good question. If I were better at making the damned thing work, I would have loved to do just that. But, alas, it sits in pieces on the bench, mocking my ignorance. I've read the articles on how to make them work, but for some reason I still get chips under the cap iron no matter what I do. Maybe because I still haven't made time to do half what those articles recommend! I couldn't find my decent block plane either! Those of you who own planes that work or electric hand planers might want to go that way. I kind of liked doing it with a chisel, though. Like I said, it made me feel like a real woodbutc…er…worker. (NOTE: Soon after making the scarphs, of course, I found my decent block plane. Sigh…)
The next step is smoothing. Those of you with planes and planers just keep on doing what you were doing before. The rest of us will get out our belt sanders! Be REAAAAALY careful with this. It does not take long at all to sand a hollow! Do that and you'll have a pocket with no wood contact! Bad! Keep the sander moving at all times. I screwed a couple up pretty badly by letting the sander dig a hole. See the photo of my hastily cut chip of wood to fill a hollow I noticed after the glue was on!
It worked out better than I had hoped, but that's a pretty big glue line for Weldwood.
Also, don't feel that the kerfs need to be GONE. You're done using the kerfs as a guide. Now you're just smoothing the surface a little so there's more contact area.
Some of these scarphs were downright beautiful! By my standards anyhow. Below is an example - one of my sheer clamps after installation. Almost too bad I'm going to paint it. Almost.
Rob fastens and glues the scarphs.
Dorado
DORADO, POWER CUDDY SKIFF, 18' X 5.5', 650 POUNDS EMPTY
Dorado is a Southern Hemisphere constellation and also this boat designed for Ashley Cook in New South Wales. The idea behind it was for a rough water power boat with a sleepable cuddy cabin. We started with my Frolic2 sailboat (which itself evolved from the Toto canoe) and straightened out the stern lines to adapt it for planing power. After mocking it up Ashley said he and family needed another 3" of headroom so Dorado B was born and built. The plans show it both ways. I should add that even though Dorado started out as a modified sailing hull, it probably would be a terrible sailer just as Frolic2 would be a terrible power boat on plane. The two worlds just don't mix and the idea of "just hoisting a simple sail" on Dorado is bound to be a sure loser both because it will sail poorly and because you will lose the simplicity of a straight power boat. Not that the idea isn't worth more study. It would take a special person to do all the tweaking involved with making the two-way boat work well.
The shape works! Ashley has been running DoradoB into the rough stuff. In the above photo he is off the east coast of Australia with nothing but ocean between him and New Zealand. He says the big curling wave to his side is a permanent fixture and fatal to boaters trying it. This sort of water is the real advantage of a bottom shape more complex that simple flat bottom, of course. A flat bottomed boat like AF4 would get beaten up badly and be clumsey in such waters. Also the more complex bottom handles better all around, especially in tight turns, than the flattie and that is why the Coast Guard will give a horse power allowable rating quite a bit higher to such a boat when compared to the flattie. The flattie has the advantage of a lot more floor space, less draft, simpler construction, and faster speed in smooth water - so flatties live on. (Ashley sent me a video of Dorado doing sharp full throttle turns, something I would never do in AF4.)
He is using a new 30 hp two stroke motor. The Coast Guard would say that is the max for this hull. With the 30 Ashley reports cruising at about 20 mph with two adults on board. As an aside I should mention that in boats like this one needs to pay attention to the prop specs to prevent the motor from going over redline at full throttle. If the usual prop is for a heavier and slower boat then I would expect the motor to rev too high at full throttle in a lighter faster boat. The idea is to select a prop with a pitch that will put the tach on the red line at full throttle.
The hull is made with taped seams needing two sheets of 1/2" plywood and eight sheets of 3/8" plywood, a total of about 400 pounds of wood. I would expect the stripped hull to weigh about 500 pounds with framing and fiberglass. I would add at least 150 pounds to that for a motor and its gear which is why I estimate the empty weight to be about 650 pounds. Add two adults and fuel and now you are around 1100 pounds total. The old rule for motors on planing powerboats is a horse for each 50 pounds so if you havea 25 horse motor you will be able to cruise this boat at 2/3 throttle. I would say 15 hp is the minimum you might use and expect to plane, even then you must stay very light and run near full throttle.
Plans for Dorado are $40 when ordered directly from me. You can also get them through www.duckworksmagazine.com.
