(1Feb04) This issue will rerun the lugsail rigging essay. The 15Feb04 issue will show some add-on rigs I've put on different designs.
Don Isleib's Piccup is ready to test drive.
RIGGING A LUGSAIL
BASIC BALANCE....
TYING ON THE SAIL...
HALYARD/YARD ATTACHMENT...
THE TACK LINE....
THE SHEET...
SAILING ADVICE...
...we look at rigging a lugsail.
Mikesboat
Prototype plans for Mikesboat are $25 until one is built and tested.
Out West the Picara project gets its bottom. Winter halts progress:
Another Picara, this one with a 1' stretch in the middle, going together in Arkansas.
