(1Mar04) This issue will rerun the issue about joining plywood sheets. The 15Mar04 issue will start an essay about figuring how much sail area your boat needs.
Mike Cerio's Slam Dink.
JOINING PLYWOOD SHEETS
BACKGROUND...Almost any boat you build from plywood will require panels longer than the 8' lengths you will find at the lumberyard. For an "instant boat" the usual manner of joining the panels together to get one long panel is with a butt strap or butt plate. I've tried lots of different ways to make the joint in the 15 or so boats I've built over the years. All the methods worked. I have a feeling that the butt joints on the usual instant boat hull are not highly loaded and not too critical to overall boat strength. Since I've tried several ways and they all worked I've gotten to be pretty nebulous about the subject on my drawings. Lately I've been specifiying a butt plate as something like "Butt plate from 3/4" x 3-1/2" lumber, or equal" which doesn't tell you much. Most builders get by pretty well with just that but recently one builder asked what in the world I meant, and rightly so. So let's start the discussion with one joint I've never tried in plywood.
What good about it? The faces are smooth both sides. Essentially you have a single piece of wood to work with after making the joint. It's quite strong, as strong as the base wood provided the taper is long enough. I've seen the taper range from 6:1 to 12:1. The shorter tapers are easier to make and probably just as good given modern glues.
THE PAYSON TEAL BUTT STRAP...
THE BIRDWATCHER BUTT STRAP...
THE LUMBER BUTT PLATE...
This is I like to advise now. Not much to it. Very quick and easy to make. Some say it looks too clunky for their tastes.
If there has been any structural problem with the above butt plate it is at the ends of a plate that joins bottom panels, ending short of the sides to allow a limber path. If the ends of the plate are not solidly glued and fastened to the bottom panels the butt plate will eventually loosen at the ends. I think that is due to the rapid change in flexibility in the system where the plate suddenly ends. A better solution might be to taper the end of the bottom butt plates starting maybe 3" in from the end of the plate and tapering down to maybe 3/8" thick at the ends. That will allow a gradual change in the flexibility and prevent a stress riser at the end of the butt plate. By the way, for any bulky butt joint care must be taken in design to see that the joints don't fall in places where the butt plate will be in the way.
We'll start figuring how much sail your boat needs.
Alansboat
ALANSBOAT, POWER SKIFF, 15.5' X 5', 300 POUNDS EMPTY
Alansboat was designed for a fellow who wanted to go fishing in the shallows. He had seen boats for fishing the wide flats and wanted something similar. He suggested an enlarged version of the 12' Twang and that is where we started.
Alansboat is 15.5' long which is about all you can get out of a panel two sheets of plywood long. The width on the bottom is 48", the width of a sheet of plywood. So you see how boats get designed around the plywood. It is essentially a flat bottomed skiff except for the Twang bow. Here is a photo that Luke Spreadborough took of his prototype Twang going together.
You can see the idea - a V bottom up front that blends into a dead flat bottom for the rest of the boat. Supposed to allow a flat bottomed boat to take a wave better than something with a flat bow. Not sure how well it works. Maybe at slow speeds but don't forget that once on plane that bow is well out of the water and she is riding only on the aft half of the hull, or less, so that V bow is somewhat out of the picture. Here is Luke's boat finished and right side up:
I drew Alansboat to be a little stouter than Twang with a 1/2" bottom and 3/8" elsewhere. Taped seam construction needing two sheets of 1/2" ply and five sheets of 3/8" ply.
Plans for Alansboat are $20 until one is built and tested. (20 hp max.)
Out West the Picara project gets its bottom. Winter shifts work to sailmaking indoors:
Another Picara, this one with a 1' stretch in the middle, going together in Arkansas. Sailmaking right now.
