(15Aug05) This issue will rerun the taped seam essay. The 1 September issue will continue the Bobsboat series.
Garth Battista's Cormorant crew, at sea. |
Taped Seams
THE INNER SEAMS... ![]()
TAPING THE OUTER SEAMS....
FINAL WORK...
YOU'RE DONE!
...We'll figure out the structure for Bobsboat.
Cormorant
All best, Garth
The AF4G is done and launched. Writeup next issue:
This long and lean project is a 19' version of Toon2. I'm told this one is more or less complete, left with the 15 % of the work that takes 85% of the time.
A Vector builder is keeping a website of the project at http://www.geocities.com/michsand@sbcglobal.net/ but in the meantime I got photos of a Vector completed by Pete Mohylsky in Florida. Here he is fussing with his sail. Hopefully a report soon:
