(15jan05) This issue will continue the series about drawing boats. The 15jan issue will rerun the essay about rigging lugsails.
Doug Snelson out for a spin in his Shanteuse.
Drawing Boats 2
TWO ISSUES BACK....
I discussed the equipment needed to draw a boat. Not much required really. No computer needed, not for now at least.
FIRST, TWO TRUE STORIES ABOUT COMPUTER DRAFTING...
Before you decide I should get with the 21st century and give up the hand drafting I will present two stories.
First goes back about 25 years when I was still a young man and an engineer at McDonnell Douglas which was converting to CAD at the time. They wanted all of us to be familiar with it and we found ourselves sitting in a darkened room, in front of a large tube with a light pen and big cables to a super computer that filled up the building next door. PC's were infants then. After a few lessons the prof asked us to bring in a pet project to practice with. I was starting boating then and had a copy of Payson's Instant Boats and wanted to draw on the tube Bolger's Teal skiff, which is nearly the simplest boat you could ever build. To recap the Teal construction, the sides are constant width planks bent around three (or was it two) forms and a shapely boat results. In fact Bolger did some very large and elaborate boats, including Birdwatcher, to the same form. All this is done without lofting or offsets. I was brand new to CAD and couldn't get the supercomputer to figure it out. I showed it to the instructor. "Simple," he said, "Just figure out the offsets and type them into the computer." {Photo of John Sellers' Teal shown below.}
I think you see the problem here. Before the supercomputer would draw the boat I had to draw it in detail in the old fashioned way and figure it all out that way. All the supercomputer could do was redraw it.
Now fast forward ten years to the second story. I've started selling my own designs and am at the blueprint shop getting prints. He also sells CAD programs there for $600 as I recall. "Save a lot of time and convert to CAD," he said. "Will the computer draw all these curved lines well?" I asked. "Of course," he said. "Just figure out those offsets and type them into the program."
Same problem as before, right? You have to draw the boat before you can use the CAD program to redraw it. We might as well fast forward another ten years to when he gave me an unsold copy of the $600 CAD program, now obsolete as to be worth nothing. I suppose I spent a month getting it into the computer and practiced only to find I could still draw it a hell of a lot faster by hand. There were other newer programs out by then that were just for boats. No doubt they are a lot better. No doubt in some applications the CAD is best. But not for little boats. In all the programs I have tried, you either end up designing the thing by hand so the computer can redraw it, or, in the case of real "boat design" CAD programs, there are limits to what it will draw as far as shaping is concerned.
So forget the idea that you will be limited by hand drafting a boat. It is quite the opposite. You will have many more options than the CAD designer.
SOME BASICS...
In using basic mechanical drawing you will see the boat in a 3 view way. Imagine your dream boat in a glass box with its side view projected onto the side face of the box, the top view projected to the top face of the box and an end view projected to the end face of the box. I don't think folks have any problem reading drawings this way since I have never gotten a complaint about not being able to understand the layout. But some folks don't design in the usual 3 view way. I've seen some done totally with sketches. And a hundred years ago it was common to build even large ships without drawings. Instead they carved a large wooden model, usually a "half hull", sort of like sculpting instead of drawing and why not? Then they took offsets from the model and then to the shipyard with it. Not sure if any real drawings were made of some of the ships. I suppose the details of building were routine to a busy shipyard so no detail drawings were needed. You can still see the old half hull models around, usually hung on the wall as "art" but they were once workmen.
A SKETCH...
Before you go to the drawing board make a sketch of what you are thinking about. I use paper with quarter inch squares on it but I'm pretty sure that Bolger, who is much more of an artist than I, uses plain white typing paper and a ballpoint pen. In one of his books he said he starts each day doing a sketch. I have to use a pencil because I make so many mistakes. Best place to do a sketch is on the water on a boat. You don't need much. Paper and pencil and maybe a scaled ruler and maybe a hand calculator. While on the water you will get a better perspective on what a boat should really be. (In one of L Francis Herreshoff's books I think there is a passage where he takes carving materials on board his cruiser to carve half hull models while underway.) Here is a sketch I did a while back (that did not become a real design, not yet at least)
You see the basics here, top view, side view, scale. I draw some six foot people in it to make sure I'm not drawing a doll house.
The end view has been placed above the others although in regular mechanical drawing it would be to the right of the other views. But on my quad paper there is no room to the right. Also I have drawn it at about twice the scale of the other views.
In mechanical drawing you can completely describe an object with two views. The third view is really not needed and in some of my plans I don't present the end view if there is not much room on the sheet. When I started drawing boats about 1980 I suppose I thought the end view was sort of just for laughs or for final fairing of a hull. But after a few years, certainly by the time I drew Toto, I came to think that the end view tells it all!
SECRETS OF THE END VIEW...
Of couse by looking at the end view you can instantly get an idea of how burdensome the boat will be. A wide flat bottom tells you it will carry a lot of weight but is not a good rough water shape. A V bottom will mean better rough water ability but maybe tippy and deeper draft. A multichine will be somewhere between. You see the flare of the sides in an instant too. Lots of flare means less capacity but probably better rough water ability.
For some reason, and don't ask me why because I don't know, you will get a nicer looking boat, at least in terms of a plywood boat, if all the lines in the end view are straight. Once you think that you sort of design things in reverse. Normally you might draw a pretty side view and then a pretty top view and then way down the road construct the end view from those two. But now I often start by drawing the end view, all with straight lines. Then you might add a top view and then the side view but by then they have become the slaves of the end view. Look at it this way: If you have the end view nailed down and draw the sheer line in the top view, the sheer line in the side view is already determined. Etc. I suspect the reason the end view all of straight lines gives a better looking boat is because it prevents you from getting too kinky with the other views. But you can tell a lot more just by looking at the end view.
If the section lines of the hull are all parallel when presented in the end view, then the planks that make the boat have no twist. This is one issue that you will need to force into your design if you are to avoid twisted planks. If the planks are not twisted then the boat will be easier to build. But maybe more important, if the planks are not twisted you will be able to determine their shape before the boat is built by conventional drafting.
Next, if the sheer line in the end view is straight, and the section lines of the side are perpendicular to it, then you know the plank that forms the sheer, the side panel in say a flat bottomed boat, can be cut with its top edge straight. That usually saves labor and materials but I found is not a major driver in a design. Like this:
And if the other hull lines are perpendicular to the section lines then those lines will become straight lines when you go to cut them to shape in a prefabricated design. Like this:
So that is how a boat like Bolger's Teal, curved in all ways, is designed from the start with side planks that are constant width and all straight lines. Panels like that sitting flat on the floor don't look like much of a boat, but when bent around forms with flare they end up with rocker and sheer sweep and all the elements of a sweet boat.
We'll come back to this in a future essay but...
We'll review rigging a lugsail.
Shanteuse
Above is a Shanteuse built in Florida by Vince SantaMaria a couple of years back but he stretched his to 24' so I couldn't really call that one a Shanteuse. But here is one by Douglas Snelson in Tennessee that looks to be right to the plans so I will call this one the prototype. He sent a bunch of photos:
As for operation, these are smooth water boats. So it is best to stay on small waters that never get too rough. On bigger waters you need to watch the weather very carefully. For power I would stick to 5 or 10 hp but I'm very much a chicken about these things. To plane a boat like this, remember the good old rule of a horse for each 50 pounds. So if you are running at 1000 pounds total you will need at least 20hp to do the job and then at full throttle. So I think you would want at least 30 hp to plane at 2/3 throttle. And this boat could easily be loaded to over 1000 pounds.
Plans for Shanteuse are $35.
