(15nov05) This issue will continue the knockdown recovery topic. The 1December issue will discuss ballast calculating.
The down under Scram, from up high.
Knockdown Recovery 2
THE CAPSIZE...
LADYBUG CAPSIZE UPDATE:
MORE PONDERING...
We'll discuss ballast calculations.
Caprice
