(1feb05) This issue will rerun the essay about rigging lugsails. The 15feb issue will continue the series about drawing boats.
Greg Flemming's Down Under Scram project, upside down.
Rigging A Lugsail
BASIC BALANCE....
TYING ON THE SAIL...
HALYARD/YARD ATTACHMENT...
THE TACK LINE....
THE SHEET...
SAILING ADVICE...
...we take another step in drawing a boat.
Blobster
Prototype plans for Blobster are $30.
