(1Jun05) This issue will rerun the essay about setting up a new rowing boat. The 15 June issue will continue the series about designing Bobsboat.
THE 16TH MIDWEST HOMEBUILT BOAT MESSABOUT will take place at Rend Lake in Southern Illinois on the weekend of June 11 and 12. Remember that lots of folks come on Friday and leave early Sunday. Take I-57 to exit 77W and then follow the signs to the Gun Creek Recreation Area. Camping at this Corps of Engineers facility is $10/night and that includes the ramp fee. There is no schedule of events except a pot luck dinner in the campground on Saturday evening - we wing it. This year some of us have reserved the campsites on the water of the two middle camping loops so look for us there if we aren't at the boat ramp.
Pete Mohylsky takes his new Vector out for a spin. |
ROWBOAT SETUP
NEXT TIME: We'll make a cardboard model of Bobsboat.
SOWSEAR
SOWSEAR, CUDDY POWERBOAT, 15' X 6", 600 POUNDS EMPTY
Sowsear was presented as a prototype design in the recent 1May issue but I knew a prototype had been built a couple of years back. Then I got a set of photos and a full report from Erwin Roux about the prototype directly afterward and I present it pretty much as he wrote it:
"Dear Jim,
Sowsear was my seventh boat so it went together pretty quickly. It took me about two weeks of evenings to get it to the stage in the photo where the hull is overturned and the bottom is glassed and painted. After that I had less time available and it took another two months to complete. Only two glitches occurred during the assembly. On sheet 2 of the blueprints the bow transom reads 9" and it is really 12". I should have used my scale instead of using what is written. The other thing was that I built the stern transom to short shaft dimensions and later found a good deal on a long shaft motor. Both problems were easily remedied. The boat was built using AC exterior Douglas Fir from Home Depot, epoxy for all joints, and was painted with latex paint. It has held up well with just a tarp over it.
The PA Fish and Boat Commission rated it at 65 HP and five person capacity. I put a 25 hp on it with remote controls and that is plenty. The boat planes at about 2/3 throttle as I recall is traveling in the upper teens for mph on the gps. I have run it at full throttle a few times but don't know top speed. I am not comfortable at all running the boat up on plane. I used a lot of epoxy and screws in assembly so I know it will hold up, but the drumming noise on the big flat bottom makes me anxious and that's not why I'm in a boat so I usually run at far lesser speeds. Seven to ten mph seems good to me. At that speed with two adults on board the boat trims better if one person heads up front. When encountering another boat's wake it is best to throttle way down and turn the side toward the wake and endure the rocking. Otherwise you'll get a nice big splash of water over the bow. This boat requires a lot of attention to the helm when the wind picks up, it gets blown all over which can make it tricky maneuvering into a canal lock. I once had it out in a dammed portion of the Susquehanna River here in Pennsylvania when the wind really picked up. Whitecaps formed and I had to quarter to the waves, which I would estimate at one foot, all the way back to the boat ramp. It was not a situation I want to be in again. The local Fish and Boat Commission patrol boat passed me on the way and they didn't seem too concerned so I guess I looked safe enough, but it certainly wasn't fun.
Sowsear is, of course, at its best when used for camping. It makes a good camper on the trailer at a campsite, although climbing in and out is tricky. I've had it on four trims of three or four days on the Erie Canal in New York. The photos show three different summers. The first summer I went by myself and just threw a tarp overthe top to camp. You can see it is very bare bones in the first photos. The next year I put running lights on, and made a cockpit softtop out of polytarp and poles. This didn't work so well so in the third year I made a hardtop with which I am very satisfied. It also fits nicely lowered down over that big cockpit and keeps the rain out when trailering and storing. On the last trip I added the side curtains and windows so it can be run in the rain. Although I have been using a polytarp cover for the walkway hatch I intend to make some sort of segmented hardtop for the walkway and doors for the bow and cockpit access. Although the bow of Sowsear is good for a beach landing, the boat is tricky to et in and out of when tied to a dock, which is basically all you do on the canal.
My son Noah, ages 5 and 6 in the photos, loves the boat. Plenty of room for lounging at his age. My nephew Kevin, also pictured at age 16, has been coming along. They slept in the cabin on air mattresses: I slept in the cockpit on a beach chair laid flat which fits from corner to corner. On my last trip my wife, son and 3 year old daughter came and we all comfortably coexisted although we heard lots of comments like "They've got two little kids in that boat, can you believe it?" We didn't get a single photo on that last trip, although enjoyable, much of it was gloomy weather and we were occupied with the kids.
Sowsear elicits either delight or derision from people who see it. Teenagers tend to point and laugh, I once got a lot of hoots and stares when I drove it down to a launch area with a lot of sparkly bass boats heading out for a tournament, and my father-in-law thinks it is the ugliest boat he has ever seen. But the vast majority of people love this boat. It is almost impossible to get in or out of a parking lot without someone asking about it. I once stopped at a scenic waterfall along the Finger Lakes and a guy who where there to renew his wedding vows came running over in his tuxedo to see it. One guy saw me from a bridge over a river and drove down to the launch area to wait for me to come in. You'll have company for hours if you decide to park it in a campsite somewhere. All along the Erie Canal people wave and smile. Docked at a canal port lots of folks will stop to ask questions. One canal worker told me people all along the canal were talking about my boat. I've always told people that you are the designer, although I am embarrased to say I just discovered I have been mispronouncing your name.
Erwin"
Thanks much to Erwin for his great letter and photos!
Sowsear plans. now updated per the above letter, are $35.
Garth has the big Cormorant to the point where his kids have taken it over and he can't get it back.
We have an experienced builder building a Mayfly16:
A Vector builder is keeping a website of the project at http://www.geocities.com/michsand@sbcglobal.net/ but in the meantime I got photos of a Vector completed by Pete Mohylsky in Florida. Here he is fussing with his sail. Hopefully a report soon:
And a Polepunt is nearing completion in Poland, of course:
