(1mar05) This issue will rerun the "calculating displacement" essay. The 15March issue will continue the boat design essays.
Vince Santamaria's Shanteuse (with an 8' extension) is still at it in Florida. |
FIGURING DISPLACEMENT
THE VERY BASICS...
One of the real basic errors in boat design is to not match the capacity of the hull to the weight it needs to carry. It's actually pretty easily done. Let's take an example: a fellow wants a 12' skiff to handle two adults. He figures the empty boat will weigh 120 pounds and the adults together at 350 pounds. So he has to float a total weight of 470 pounds.
One thing is for sure: no matter what the shape of the hull, it will sink into the water until it pushes aside, or displaces, 470 pounds of water. (The way I heard it was that ancient Greek mathematician Archimedes figured out the basics while sitting in the bath tub.) Fresh water weighs about 62 pounds per cubic foot and salt water usually about 65 pounds per cubic foot. So the volume of fresh water displaced by the 470 pound boat is 470/62 = 7.6 cubic feet. That was easy!
We talked about the prismatic coefficent a long time ago and you should be able to look it up in the way back issues index. Basically we construct a prism with the same length as the waterline length and the same cross section as that of the boat's maximum beam. The hull will fit neatly into the prism. Divide the volume of the underwater hull by the volume of that prism and you have the prismatic coefficient.
Remember that the prism has the same length as the hull's waterline length and underwater cross section as the boat's maximum cross section. Remember we want a 12' boat, but the waterline will be shorter if we want some rake to the ends (for looks) and maybe enough rocker to make sure the stem and stern don't drag the water (for low drag). We might guess that the waterline length will really be about 10'. Then the maximum cross section would have to have 13.8/10 = 1.38 square feet of area below the waterline. If we wanted a flat bottom 3' wide (wide enough to have sailing stability and narrow enough for reasonable rowing) we would have a draft of approximately 1.38/3 = .46' or 5.5".
METHOD 2: THE CURVE OF AREAS...
This method of the "curve of areas" is an accurate and flexible way of determining the volume of almost any oddly shaped thing. It's actually pretty easy to do but first you need a drawing of the proposed boat (unlike the prismatic coefficient which just needs a general idea of the boat).
Next we graph those underwater areas spacing them the same distance apart as they are on the real hull to get the "curve of areas" like this:
The area enclosed under the curve of areas is a volume and is indeed the volume of the underwater hull - it's what we are looking for. In the old days you would measure the areas with a planimeter, a clever and expensive gadget. But you can do well by just breaking down the curve into triangles and trapezoids, figuring the area in each trapezoid, and adding them all up. In the example, second trapezoid from the left is figured by 1/2(175+209)X12 = 2304. Adding the sections together gives us a total of 12500 at 5.5" draft. That equates to 450 pounds of water. So the first guess was off by 20 pounds or about 4%. By the way, the drawing showed a waterline length of 9'5" instead of the first guess 10'.
THE COMPUTER METHOD...
We'll apply this to the new Bobsboat design.
Alansboat
ALANSBOAT, POWER SKIFF, 15.5' X 5', 300 POUNDS EMPTY
Alansboat was designed for a fellow who wanted to go fishing in the shallows. He had seen boats for fishing the wide flats and wanted something similar. He suggested an enlarged version of the 12' Twang and that is where we started.
Alansboat is 15.5' long which is about all you can get out of a panel two sheets of plywood long. The width on the bottom is 48", the width of a sheet of plywood. So you see how boats get designed around the plywood. It is essentially a flat bottomed skiff except for the Twang bow. Here is a photo that Luke Spreadborough took of his prototype Twang going together.
You can see the idea - a V bottom up front that blends into a dead flat bottom for the rest of the boat. Supposed to allow a flat bottomed boat to take a wave better than something with a flat bow. Not sure how well it works. Maybe at slow speeds but don't forget that once on plane that bow is well out of the water and she is riding only on the aft half of the hull, or less, so that V bow is somewhat out of the picture. Here is Luke's boat finished and right side up:
I drew Alansboat to be a little stouter than Twang with a 1/2" bottom and 3/8" elsewhere. Taped seam construction needing two sheets of 1/2" ply and five sheets of 3/8" ply.
Plans for Alansboat are $20 until one is built and tested. (20 hp max.)
The prototype River Runner is complete but the builder sent some nice "in work" photos that I hope to run. Here he has prefabbed all the required parts.
