(1nov05) This issue will rerun the knockdown recovery essay. The 15 November issue will continue the topic.
John and Sue McDaniel are building a big steel Bolger instant boat!
Knockdown Recovery
And now on to our story...
AF3 CAPSIZE RECOVERY...
"Hi Jim:
At summer's end he wrote:
"Hello Jim:
Herb"
...More capsize stuff.
AF3
AF3, CUDDY SHARPIE, 16' X 5', 250 POUNDS EMPTY
The AF3 (the original design study was called "Alison's Fiddle") prototype was built by Herb McLeod of Edmonton, Alberta, with 70 hours of labor. He used spruce exterior plywood made at the plant he has to drive past on his way to the lumberyard.
The sail rig is the exact one I used on my old Bolger Jinni and it also found its way onto the Pencilbox design. I align the sail area directly above the trailing edge of the narrow leeboard on sharpies. If weather helm becomes a problem (hardly ever happens) you can dial it out by sweeping the leeboard aft. Traditional teaching would have the sail much farther forward but that guarantees lee helm in a boat like this. I'll bet the old rule about "lead" in sail layouts applies well to the sharp deep cutwater hulls of traditional planked boats.
Also I've shown external chine logs on AF3 and all my sharpies. They are an easy, quick, and strong bottom attachment, but many can't accept their looks. Use traditional interior logs if you wish. Better yet, use epoxy/fiberglass tape chine joints with a healthy interior radius. That makes for a really clean looking boat and the worst rot area in a wooden boat, that chine log, is totally eliminated.
AF3 is suitable for camping one person in its cabin and there is not a lot of room in there. If you would like a larger version of it try the 18' Normsboat or the 20' AF2 that you can find in the online catalog.
AF3 uses six sheets of 1/4" plywood and two sheets of 1/2" plywood. Plans are $30.
There are some other AF3's out there and I think I can include all the AF3's I know of. Herb's friend Gordon built this one:
Remember Frank SanMiguel in Colorado:
Pierre Yves Gabi built this one shown with the Swiss Alps in the background:
Max Wawrzyniak built this one in St. Louis:
And Chris Feller finished this one with a lug rig. (Anyone wanting the lugrig drawing contact me.)
