(15aug06) This issue will start a series about panel stiffenss. The 1 September issue will rerun the important taped seam essay.
Another yellow boat in Chicagoland. Chris Feller's new Piccup Squared awaits its first dings.
Panel Stiffness 1
FIRST, THE BASIC BASICS...Let's say you have a bar or stick of material that is 1 square inch in cross sectional area. You mount it in a testing machine that will apply a load in tension and will record that load plus the amount the sample stretches during the loading. Like this:
If you run the test until the sample fails totally you might see a curve of load/deflection that looks like this:
All structural materials act sort of like this with variations. To walk you through what is happening, the testing machine starts to pull on the ends of the bar and the machine records the load and the deflection of the end of the bar that corresponds to that load. In the first phase of the stretch, the load and deflection go up in a straight line. Double the load and you get double the stretch. Until you hit the "yield point" of the material. Then something happens. If the material is brittle, like cast iron (or a weld), it will break all at once. But if the sample is not brittle, say like soft steel or aluminum, it will continue to take more load. However it will deflect a lot more than it did per unit of load than it did up until the yield point. Some materials like the softer steels used in building construction can stretch beyond the yield strength to twice that strength, with enormous deflections. Such structures can give a lot of warning when they are overstressed and that can be a safety factor. In general if you strengthen a metal by heat treatment you can get dramatic increases in the yield strength but not so much in the ultimate strength.
Some typical values of common materials used in a boat might be:
Stainless steel, yield stress 78,000 psi, ultimate stress 125,000 psi
Aluminum: yield stress 60,000psi, ultimate stress 68,000
Spruce premium lumber: yield stress 7000psi, ultimate stress 10000psi
I got these values out of an old handbook. The values can be misleading in that there are many different alloys of metal and qualities of wood so that your mileage may vary.
BY THE WAY...
If the machine pushed down on the sample to compress it instead of stretching it you usually get a similar curve going in the other direction. Sometimes the idea of "ultimate compressive failure" can raise an argument say when you have a soft metal that simply mooshes down (a technical term I don't have the time to explain) such that it never really falls apart in compression. But most metals have a yield strength in compression that is about the same as the tensile yield strength. Wood is different, at least in my handbook. Spruce has an ultimate compressive strength of just 5600psi, about half of its tensile ultimate.
IF THE LOAD IS REMOVED...
... before reaching the materials yield strength, the bar will shorten as the load is removed right down the original load/deflection line until it has zero deflection again. Like this:
The slope of that initial line to yield strength is a big deal. Think of it as a "spring rate" in that your bar stretches so much per unit of load. The slope of that curve is called the "modulus of elasticity" and is usually given the symbol of a big "E". For example the E for steel is about 30e6, Aluminum about 10e6 and spruce about 1.5e6. Engineers use these values to predict deflections but you might just think of it as saying "steel is three times as stiff as aluminum, and twenty times as stiff as spruce" but remember that the number is hung on a square inch sample cross section, and then remember a cubic inch of steel weighs about three times as much as aluminum and twenty times as much as spruce. So now things can get blurred in an interesting way.
Here is another something interesting to those of us who are easily entertained. The density and E of metals is hardly affected by the alloy or heat treatment of the metal. So if the shop guy tells you he will increase the stiffness of your spring by heat treating it, something ain't right.
AS AN ASIDE...
If you load the bar past the yield strength and then remove the load, the sample does something interesting. It returns down to zero load but retains a bit of deflection - it has a permanent stretch! Like this:
Then if you load the sample again it will go UP the red line it just came down until it reaches the the line to the ultimate load again. Then its new "yield" strength is going to be higher than its original yield strength. I suppose it is being "work hardened".
But in general things are not designed to be used past the original yield strength. They can go up and down that same line millions of times without any added stretch as long as the yield strength is not exceeded. When I was in the missile factory we ran things right out to the "ulitmate" strength all the time since the missile was supposed to be on a one way trip - we didn't care if it stretched along the way. But ordinary things aren't designed that way. They are supposed to be reused over and over.
I don't know when this elastic behavior was first discovered but most likely it was in mid 19th century. Since then almost all structural theory is wrapped around this linear elastic behaviour and it works quite well.
NOW WE MOVE ON TO ANOTHER BASIC...
Let's say a fellow puts a 2x4 across a pair of saw horses and sits on it, like this:
The board deflects into a curved shape.
Now here is a big idea that engineers use to solve their problems. If the board is now curved, and you have a material that has linear elastic behaviour as discussed above, then the stresses inside the board can only be like this:
What has happened is that the only way the board can curve in the way shown is to have the top fibers get shorter (by compression) and the bottom fibers get stretched ((by tension). In this simple example the total amount in compression has to equal the total amount in tension. Fibers away from the top and bottom MUST lengthen or shorten in the pattern shown in order for the board to keep its continuity. The fibers in the middle, on the "neutral axis", don't change length so suffer no stress due to stretching or compressing.
Actually with the info given so far, we can calculate the stresses in the board under the man's weight. The bending moment (or torque) under the fellow's bottom is 100# times 48" or 4800 inch pounds. It can only be resolved in the center of the board like this:
Note that the answer is only dependant upon the geometry of the things, not on the material used. So the answer would be the same in steel, aluminum, wood, or any material with the 1.5" x 3.5" cross section and linear elastic behaviour. So the fellow has 3660 psi stress under his butt. No sweat to aluminum or steel but it might break that cheap 2x4!
We will get back to this in a couple of issues. But...
...We'll rerun the important taped seam essay.
Cormorant
All best, Garth
