(15mar06) This issue will do more sail rig figuring for the new Raider design. The 1 April issue will take us along the Extreme Challange 2006 with Gary and Chuck.
THE REND LAKE MESSABOUT WILL TAKE PLACE ON JUNE 9, 10 AND 11 AT THE GUN CREEK RECREATION AREA AT REND LAKE IN SOUTHERN ILLINOIS. MORE DETAILS WILL FOLLOW BUT IT MIGHT BE PRUDENT TO MAKE CAMPING RESERVATIONS IF YOU INTEND TO ATTEND.
Gary Blankenship and Chuck Leinweber depart Tampa in Gary's Frolic2, destination Key Largo.
Raider Design 3
BACK TO THE RAIDER, AGAIN....
To review, last time we looked at Raider we got into more details with the sailing rig.
I did not size the rig in my usual way since the Normsboat sailrig was already at the builder's hand and a "given". But after thinking about it I decided to take a second look at it, just to be sure it would not be overwhelming and also to get a idea of the power a hiking crew can produce on a boat like this.
First, I got out my Hullforms model:
I took a look at it's waterline at 1100 pounds total which I take to be the total of a 400 boat with 700 pounds pf crew. It floated right as desired, with the chine just touching the waterline:
Then I varied the heel angle in the program until I knew how far it would heel before water came over the side. Turns out that happens at 35 degrees, like this:
There would be no point in worrying about righing moment beyond that point.
Just for the fun of it I ran the option where Hullforms draws a righting moment curve with the hull empty, at 182 kg which is 400 pounds. I got this:
By dumb luck the maximum righting moment occurs at a roll angle of 35 degrees, the same as our swamping angle. So we aren't losing any performance by being too low sided. Let's see, it says the max Gz, the righting arm, is .12 meters, which is 5". So the naked hull would capsize when a rolling moment of 5 x 400 = 2000 in lb is applied. That really isn't much. For example, this hull is 60" wide so force of just 67 pounds applied to the wale at the hull's widest point will cause it to capsize. One must be careful when boarding to step into the middle of the boat. With a deep V boat this is not a surprise.
Next I ran the same option at the normal operating weight of 1100 pounds (500 kg). I got this righting moment curve:
Still not a lot. The maximum righting arm is .14 meters (5.5") and with a total weight of 1100 pounds, the maximum righting moment will be 5.5x1100=6000 inch pounds. Most of the added stability is just from the extra weight. The waterline has changed and gotten wider so the stability due to the shape of the hull has also increased a bit. But this might be the curve to use while if the crew keeps their weight centered in the hull, as they would while rowing while sailing.
Ok, now the question is how hard will the wind blow to make this rig capsize the boat with the crew centered? This will assume the boat is close hauled and most of the sail force is sideways, only a small percentage of the sail's force is pushing the boat forward, most of the sail's force is pushing the boat sideways and that force is opposed by the leeboard way down low. On this rig the center of the sail and the center of the leeboard are about 14' apart, or 168". So a sideways force on the sail of just 6000/168=36 pounds will cause her to swamp. How does that relate to wind speed?
There are a lot of assumptions required here, getting from wind speed to sail force. I suppose the main assumptions are that all of the sail area is effective (that may not be true due to sail twist, etc.) and the "efficiency" of your sail. But the force on a sail, as with an aircraft wing, is usually shown to be:
F=.0034 x S x C x V x V where:
F is the force in pounds. S is sail area in square feet, V is wind speed in knots, and C is a "force coefficient". We know the sail area of a Normsboat sail is 115 sq ft. We are trying to solve for V. C is going to be about 1.5 for a "good" sail but can vary from maybe 1 for a crude sail to maybe 2 for a super sail.
So we have 36 = .0034 x 115 x 1.5 x V x V which equals .58 x V x V. Or rearranging we get V x V = 61. A quick look at the calculator shows V = 7.8 knots in this condition will capsize the boat. I would think the crew could try to row/sail in those conditions. It would be a noticeable breeze and then some. Most likely some of the crew will have to drop their oars and hike to one side to keep the boat level so those rowering could still row.
CREW WEIGHT TO WINDWARD...
If it breezes up some more, what to do? You could reef down and keep rowing but most likely you wouldn't want to do that. Instead the crew could drop their oars and all "hike" out to windward. Like this:
As you see, If the whole crew of 700 pounds gets into the hike then there is a potential righting moment of about 17000 inch pounds available. There might actually be more since I am showing the situation where the hull is not heeling. If the hull heels some then it will pick up some form stability but it will start to lose the effect of the hiking crew (you can imagine that if the boat heeled to say 90 degrees then the effect of the hiking crew would be nothing or negative).
So now what sort of wind speed are we talking about? 17000 inch pounds divided by the spread of sail/leeboard of 168" gives us a sail force of about 100 pounds at capsize. So we have 100 = .0034 x 115 x V x V = .58 x V x V and V x V = 100/.58 = 172. Another glance at the calculator gives V =13 knots.
That is a good breeze with whitecaps, crew hanging over the side to keep her down and the rail down! No need for oarsmen now. Looking at it that way I'd say the size of the sail is OK.
And this is by no means extreme hiking. That might take the form of sitting on the rail or hanging over the side of the boat on a trapeze that is lined to the masthead, Or maybe a "hiking board" as used in extreme racing canoes that puts the crew many feet over the side of the hull. Of course, if the wind lulls while you are doing this you will capsize backwards!
There is another important bit of info to glean from this. Let's say the mast at its root is 3" square, this at a point about 120" from the sail center, so the bending moment on the mast at that point, with the crew sitting to the side, is 100 x 120 = 12000 inch pounds. The elastic bending stress in a square cross section is equal to 6M divided by the thickness cubed, that is the mast thickness is multiplied by itself twice. So the bending stress in this proposed mast would be 6 x12000/(3x3x3)=72000/27=2700 psi. This is below the allowable for almost any sort of wood and in the best selected woods like Sitka spruce we might push bending stress to maybe 5000 psi or more. But I would not push my luck here since there are so many variables and breaking a mast will only happen at the worst possible time and will be a disaster.
...I hope we can join Gary Blankenship and Chuck Leinweber in a review of sailing Gary's Frolic2 from Tampa to Key Largo in the Extreme Challange 2006 race!
PICCUP PRAM
Here is another by Doug Bell:
This one is by Jim Islip:
And this one by Ty Homer:
