(15nov06) This issue will complete the capsize essay. The 1 December issue will speculate on power requirements..
Knockdown Recovery 2
THE CAPSIZE...
LADYBUG CAPSIZE UPDATE:
MORE PONDERING...
We'll ponder power requirements.
Caprice
And here we have an LHF17 rowingboat. The boat is being assembled now and the builder reports it to be at the limit of the taped seam method because of the wicked twist in the garboard. That would be true with any building method but perhaps the real Herreshoff builders used steamed planks. The builder also doesn't like the method of blending the ends of the planks into the stems (I copied from Bolger) using putty and tape saying he would prefer traditional rabated joint. Not a project for the first timer!
