(1feb06) This issue begins a discussion of a new design. The 15feb06 issue will continue the subject.
Chris Hill takes his Vireo14 out first time.
Raider Design #1
I TALKED TO A FELLOW....
...who had lived for a while near the Baltic Sea and still visited there often. He had participated in a "RAID" event there recently. He explained that a Raid event is sort of an escorted tour of row/sail boats which would cover several days and a lot of water but was not "roughing it" in that the boating was limited in time each day and housing and meals were provided for by the tour. It sounded to me of perhaps what the Tour de France bike event may have started as long ago but now that has become the most intense racing around. In the same way the Raid event is getting more serious in speed.
So he wanted a row/sail boat with the ability to seat four oarmen and a sail rig that could fold down quickly when rowing was serious and be raised quickly for times when it could be used to advantage including legs where folks would row while the sail is up and drawing. No need for a motor at all. No need to carry any extra gear or supplies since the tour support boats are always nearby. He told me to expect the four oarmen to total 700 pounds in weight.
SIZING IT UP...
So as we sized up the project we talked about 700 pounds of people and maybe 400 pounds of boat or about 1100 pounds total displacement. And room would be needed to let four oarsmen do their work. The sail rig would play second fiddle to the rowing (and I would suggest that the same boat with no sail rig but with trained oarsmen would outrun the row/sail version, but they might not enjoy the tour).
Now, if you sit on a low rowing stool, say no more than 12" high, you will find you need at least 3' of space from seat back to foot brace. I thought we might go for 4' to allow for bulkheads, etc.. Four rowers that way gives 16' of boat just for the crew, add a nice bow and stern and you are at about 24' total, and Norm agreed.
Shallow water was of no problem and although I thought the water might be wicked cold Norm assures me that at summer's end the Baltic water can be very nice and hopping out with wet feet no problem. With that in mind there was no need for a flat bottomed beaching boat and I suggest a V bottom as being the fastest thing to row. (It's shape would be a lot like that of Chis Hill's Vireo14 shown above.) Beam would need to be about 5'. More than that and the handling of oars might get difficult. Less than 4' and you get the same problem. This boat would be optimized for rowing so we would go with 5' giving a long narrow hull. It would also be fairly low to give good oar action. Sketching it up we ended with this on first try:
If we knew the overall size, the only thing left to guess at was how deep the V needed to be to float the weight. We wanted to float 1100 pounds in such a way that the sharp chines of the bottom/side joints would be out of the water in normal trim so no water would flow across them.
Now, when a boat pushes down into the water it makes a hole in the water. How big is that hole? The weight of the water displaced by the hole is equal to the weight of the boat. So here we have 1100 pounds to float, water weighs about 62 pounds per cubic foot, so the hole here would be about 1100/62 = 18 cubic feet. Now, our 24' hull is not going to make a hole 24' long because the bow is overhanging a bit. Let's say the effective water line length is 22' long. And the hole is 5' wide at its max. Now imagine a prizm that is 22' long, 5' wide and with a V cross section of depth D. Like this:
This prizm has a volume of .5 x (22 x 5 x D) which works out to 55D cubic feet. If our boat were just that prizm it would displace 62 x 55D = 3410 x D pounds of water. But our boat is streamlined on the ends a lot and does not displace that much. What boat designers have done over the years is keep track of how much the streamlining affects that prizm's volume and called that the "prizmatic coefficient". I've kept track of mine and can say with pretty good confidence that any normal rowing or sailing boat will have a Cp of .50 to .60. If you called it .55 you would always be within about 10% for this first guess which ain't bad. This boat is on the fine end of that range and I would use a first guess Cp of .50. So Raider would make a hole in the water that displaces about .5 x 3410 x D = 1700 x D pounds. If we are trying to float 1100 pounds, then we make the depth of the V at D = 1100/1700 = .65' which is about 8".
I GO METRIC...
So far I'm thinking all in English and so was Norm but he said the boat would be built in the Baltic and the plans would have to be in metric. I tried that about ten years back but gave up on it after a quick check showed a US builder who wants to work in metric has to special order all his tapes and tools. Well, now it is time for me to enter the nineteenth century. At first I thought I would design in English and convert the numbers to metric but that would mean the builder would always be working in oddball dimensions. So I gathered up some metric measuring sticks and dove in. No more working in 1/8 or 1/12 scale. But 1/10 scale fit well on my 2'x3' paper.
When I drew the lines I made it a convenient 7.3 meters long and 1.4 meters wide on the waterline, then 25cm deep in the V and added a bit of topside flare for looks for a top width of 1.5 meters. I made up a Hullforms model (which will work in metric) using offsets from my drawing and got this:
In 3D it looks like this:
It looks like this with some skin on it, very much like the Vireo14:
Hullforms told me on level trim she floats 1100 pounds at 9" draft so my guess was close. At 1320# she sinks 9.6" deep and at 1540# she sinks 10.2" deep. So when her sharp chine hits the water she will float about 1400 pounds which is more than we think we need. But everything gets heavier as time goes by....
We muddle through the Raider sail rig.
Blobster
Prototype plans for Blobster are $30.
