(15aug07) This issue will take a second look at that Shanteuse hull shaping thing. The 1 September issue will rerun the taped seam essay.
Shanteuse Shaping 2
WELL, WHERE WAS I......A couple of issues back I used Hullform to look at the drag of a Shanteuse hull, both the standard squared stern motorboat version, and a swept up stern version like Bob Williams had built for a sailing Shaneuse.
Here is a photos of the blueprint Shanteuse hull as built by Doug Snelson:
And here is the modified hull built by Bob Williams:
The idea behind the swept up stern of the sailing Shanteuse was to reduce drag at sailing speeds. But the Hullform study showed there was about no real difference in drag between the two hulls at slow speeds! Then I got a letter from someone who agreed with my guess that the powered straight tailed version might have lower than expected drag because it has a longer waterline than the sailer and because the draft of the boat is so low at normal weights that the drag of the wide flat transom is not high, it does not have a "deep" transom like many motorboats even though there is no upsweep to its stern. I don't recall the draft of the boat but it clearly would be just 2 or 3 inches. The writer also mentioned that Phil Bolger once proposed a similar test between two real boats made to his Brick design, one with the standard rockered stern hull and another identical but with a straight flat stern run like Shanteuse's. Well, that did it for me. I don't mind being 20 years behind Bolger, he is almost always on the right track about things. I take it that Phil was thinking also that the tiny draft of the flat run Brick plus its longer waterline would make for a boat that sailed with the original Brick but would be much better under power.
FOR A SECOND LOOK....
... I think I will alter the trim of both shapes to see the effect of making the stern draft deeper. Then see if Hullform will show any drag difference during heeling during sailing, another thing that will make for a "deeply immersed transom" in the power boat shape but should make little diff in the swept up sailing hull. I've got to admit I am doing the calculations as I am writing this and have no idea how they will turn out, but that is good science!
LET'S LOOK AT THE EFFECT OF TRIM...
This is easily done with the newer versions of Hullforms since you can make it graph drag/speed curves over a range of cg locations. For the original calcs I put the cg where the boat would float level. Now I will move it aft, immerse the transom deeper and see what happens. For that original powerboat hull I used a weight of 1200 pounds with the cg 9.8' aft of the bow to get level trim with 3.5" of draft. I varied the cg from 10 to 13' (pretty extreme for a 16' boat) and got this:
Clearly trim has little effect until about 3.5 knots. Then the drag goes very high for the trim with a deep stern, about 10" deep for the cg=13 case. I can tell you that the bow of that boat is very much high in the air at that trim and looks like a rocket on takeoff. It is highly unlikely that anyone would load a boat that way and expect to get anywhere.
Now let's use the same cg variation on the swept up sailing Shanteuse. With this boat level trim was achieved at cg=7.75' which resulted in a draft of 4.4". In the test I varied the cg from 8" to 11' and got these results:
Now these is a difference. The sailing hull with cg at 11' has its transom just kissing the water, it is a very extreme trim but the transom is not immersed and the graphs show there is little effect in trim, something you would hope for with such a boat.
For the power hull it appears that at 5 knots the drag hovers around 60 pounds or so as long as the trim is not too extreme. For the most extreme trim shown drag jumps to say 340 pounds at 5 knots but I doubt if any serious boater would operate his craft that way.
For the sailing hull the drag at 5 knots varies from about 70 pounds to 110 pounds. At exteme trim the max value looks to be a lot less than that of the power hull, really about a third as much. So the sweep of that sailing stern helps in extreme trim situations but not in normal trim! Pretty much what we learned a month ago. One must remember that the advantage of the swept hull is probably no real advantage since it happens at an extreme trim that only a land lubber would accept.
LET'S LOOK AT HEELING DRAG...
It occurred to me that Hullform might calculate drag of a hull that is heeled in sailing. Let's see if it will. Here is the drag prediction of the sailing hull with zero heel angle:
Drag looks to be about 60 pounds at 5 knots. Now let's look at 30 degrees heel:
WOW! I wasn't expecting that. Hull drag at 30 degrees heel is about half that of upright. It is well known that some hulls sail best when heeled but this is quite a change. Is Hullform doing this correctly? I have no idea how the drag is calculated but I know the times I have tried to measure the drag of a real hull the results agreed with the Hullform prediction. Now, there might be another problem - trying to really sail the Shanteuse at 30 degrees heel might be a bit of work. But clearly if you have a hull like this you should look into keeping it heeled when sailing.
Now we will try the same curves with the straight sterned power hull. With no heel we get this drag/speed curve:
Drag at 5 knots appears to be about 60 pounds, less than the sailing hull with no drag. But the curve at that point seems to waver a lot, a hump and a dip, and when I did drag tests on AF4 a while back these humps and dips never could be seen in the tests, the results were a smooth curve. Now the same boat at 30 degrees heel:
I was afraid of that. Only about 16 pounds drag at 5 knots, less again than the sailing hull. Well, I don't believe it. What else can I say. Still best to present this stuff even though I can't expain it. Must not forget that Hullform drag predictions have proven good in the past although I never tried the heeled drags.
Well, Bolger is right again - you have to build two real hulls and test. Then I'll believe it. One last comment is that I would expect the handling of the sailing hull to be superior to the power hull if these were both to be sailed.
...We'll rerun the taped seam essay.
Cormorant
All best, Garth
HOLY COW! A Jukebox2 takes shape in Minnesota. Unheated shop means no work during the winter. Check out that building rig! (Wait a minute! I just got a CD of photos of a Jukebox2 finished in the Sydney, Australia area by Ted Arkey!)
And the Vole in New York is Garth Batista's of www.breakawaybooks.com, printer of my book and Max's book and many other fine sports books. Boat is done, shown here off Cape Cod with mothership Cormorant in background, Garth's girls are one year older. Beautiful job!
