(15jul07) This issue will look a bit into the shape of hulls. The 1 August issue will rerun the all important "sail area math" essay.
Bob Bean goes for a spin in his new Jonsboat.
SHAPING SHANTEUSE
REMEMBER THIS PHOTO???
This is Bob Williams' modified for sailing Shanteuse. Note that the stern has been swept upward on the bottom to match the sweep in the bow. But Shanteuse was designed to be a pure powerboat and thus had a straight wide stern, as shown here in the first prototype by Douglas Snelson:
So what's the diff??
PHIL BOLGER'S ADVISE ON POWERBOATS....
... is that a hull designed with a straight wide stern will run OK at slow speeds and OK at high speeds. A hull designed only for slow speed operation will be better than the power hull at slow speeds and hopeless at high speeds. Essentially it will not run at high speeds hardly at all due to control problems even if it has enough power to push it through. The high speed hull on the other hand will be at a speed disadvantage, with no control problems, at slow speeds but it can kick up its heels and fly at high speeds. So if you are thinking in terms of moving faster than a fast walking pace you almost have to go with the deep wide stern of the modern powerboat.
Why bother with the slow speed shape at all? Because craft like rowing, paddling and most sailing boats are working with very small amounts of power, say 1/10 th horsepower. They will never plane and need all the low speed advantage they can get.
Anyway, Bolger is almost always right. Let's look into the Shanteuse shape changes with Hullform to scope this out.
I made up a model of the original deep sterned Shanteuse with Hullform. Here is a tilted view:
I ran the speed/drag feature up to 8 knots and got this for the deep transom standard Shanteuse:
I'm not sure if the little hump just short of 5 knots is for real. When testing my AF4 I never could measure such small waves in the curve. Beyond 5 knots the drag increases an awful lot. I don't show drag beyond the "hump" but it falls to about 150 pounds and then starts its own steady climb.
It might be worth while to figure the power needed to clear that power hump. It is about at 6.5 knots which is about 650 ft/min. And drag then is about 280 pounds. That makes for 650 x 280 = 182000 pounds times ft/min. One horsepower is 33000 pounds times ft/min so this is 182000/33000=5.5 hp. But that is real hp pushing the prop forward and our AF4 tests showed again and again that only about 35% of your rated hp is pushing the boat, the rest is lost mostly in prop inefficiencies. So I would expect a Shanteuse at 1200# total weight to need at least 15 hp to clear the hump. It's a big boat and that is no surprise.
NEXT...
I modeled the Shanteuse as a shallow sterned boat with the bottom sweeping above the waterline exactly as it does at the bow. Here is the model:
And here is the drag curve for that boat at 1200# total weight:
I see no real difference - if anything the deep sterned boat has less drag! Confused? So am I. I would pass it off as bad theory but these Hullform things have proven to be correct to a certain extent almost all the time. It might be because of the shorter waterline of the swept up stern. And in this boat the "deep" powerboat transom is not really that deep. I guess Bolger warned us about this.
NEXT TIME: We'll refresh our sail area math.
Shanteuse
Above is a Shanteuse built in Florida by Vince SantaMaria a couple of years back but he stretched his to 24' so I couldn't really call that one a Shanteuse. But here is one by Douglas Snelson in Tennessee that looks to be right to the plans so I will call this one the prototype. He sent a bunch of photos:
As for operation, these are smooth water boats. So it is best to stay on small waters that never get too rough. On bigger waters you need to watch the weather very carefully. For power I would stick to 5 or 10 hp but I'm very much a chicken about these things. To plane a boat like this, remember the good old rule of a horse for each 50 pounds. So if you are running at 1000 pounds total you will need at least 20hp to do the job and then at full throttle. So I think you would want at least 30 hp to plane at 2/3 throttle. And this boat could easily be loaded to over 1000 pounds.
Update, 2007. Bob Williams brought a sailing version of Shanteuse to the 2007 Rend Lake meet. He worked the sail rig out totally on his own, they are not on the plans. He also swept the stern bottom up to improve low speed performance. Here are a few photos of his boat:
Plans for Shanteuse are $35.
And the Vole in New York is Garth Batista's of www.breakawaybooks.com, printer of my book and Max's book and many other fine sports books. Boat is done, awaits water. Beautiful job!
