(15Nov07) this issue will present some changes I am making to my AF4. The 1 December issue will rerun a knockdown recovery essay.
My AF4 Changes
I MUST BE GETTING OLD...
...as I found out this summer. I strained my back doing nothing in particular and for two months suffered on and off. It affected my boating. I was using my old Birdwatcher for the most part since my AF4 is also sort of laid up. Early in the season as it sat on its trailer in the shed I threw a bucket of water into the cockpit to see how badly it would leak. Several buckets later I decided it was time for a new bottom. But that would be a winter project. Using the Birdwatcher again about twenty days with a sore back had me appreciating all those "step through" bows I had designed although I never had one for myself. The Birdwatcher really isn't too bad in that respect - boarding from a beach. The AF4 is worse, about a 30" leap of faith from ground to deck and back. Here is my AF4 two years ago on a busy weekday at Carlyle Lake (sort of have the whole place to myself on weekdays):
I had been thinking about ways to make it easier to board for a long time. When I'm healthy I usually sit on the little bow deck and swing my legs around into the deck slot. Then it is 3' down inside to the bottom. Egress is the reverse. Normally not a huge deal but a sore back would make you think twice about it and maybe you would decide on a different hobby for a while. I suppose I've been cruel since it was clear my wife had no interest in that leap of faith from the start. Anyway, as the boat sat in the shed over the summer I pondered an easier way to get aboard. Then one day I grabbed saw and started hacking. "If I'm going to ruin the thing with a new boarding idea I'd better do it now before getting involved with a new bottom," I told myself.
FIRST TO EXTEND THE SLOT...
...and sort of eliminate the little front deck. First I found an old 2x4 that might make extensions for the current deck beams. I found that by splicing extensions to the insides of the current beams the width of the extensions would bring them right to the corners of what remained of the little front deck. These extensions were glued and screwed to the existing beams and to the deck. The center of that deck and the beam that formed the front of the slot were chopped away. The chopping did not seem to harm the stiffness of the structure there as a short parallel bar routine on the deck beams showed.
SECOND I CHOP AWAY THE BULKHEAD...
..., not all of it of course. In AF4 the volume in front of this bulkhead is free to flood and has drain holes in the bottom. So that pointy bow is really a fairing, the real boat starts at the bulkhead. I whacked it down so that it was 20" from bottom to the new top and that should be plenty of freeboard there. So the new step through is about 12" lower than the old. I made a drop board from some scrap plywood to fill the new hole. So far so good.
THIRD, AN INTERIOR PLATFORM...
...that would do double duty as a shelf and as a step. This was placed about halfway between bottom and the new bulkhead opening, about 12" off the floor. So now a fellow could step up 12" to the platform and then up another small bit to the edge of the new opening, a huge improvement over the 3' leap of faith. Here is a photo of the old setup:
And here is a photo of the new:
My battery and toolbox are still to go underneath where they always stayed, and that high tech electrical system can mostly stay in place.
AND LAST, A DOOR...
...The door had me stumped. This was going to be in the pointy bow. Remember that the pointy bow is not watertight on AF4, so leaks would be no problem. I chopped an opening in the starboard side wide enough to step through and down to 15" from the bottom. I tried it on and found I could step from the level outside the bow bottom, as say the beach would be from the beached boat, right onto the interior platform in one stretch if I felt like stretching. Otherwise it is a short hop through that bow door, onto the edge of the bulkhead opening and then like a gentleman onto the interior platform and then to the bottom. But when I exited I found at least in trials in the shed that the door needed to be larger so you can see where I had to whack at it again and reglue the old whacked piece onto the enlarged door. I am hoping that the new door, if I forget to close it, will not be a factor in boating. I think dangling down it will come to no harm (I don't intend to test that on purpose but fully believe it will get tested, probably at some critical time).
I hope my wife likes it.
NEXT TIME....
We capsize some boats.
Caprice
An Bill McKeough in Oklahoma has completed what I think is the first Dockbox. He narrowed it from 5' to 4' so it would fit his utility trailer but it still is a Dockbox to me. Details soon.
