(1jan07) This issue will rerun that September 2003 article where I measure prop thrust. Next month we will jump back to guestimating hull drag.
Measuring Prop Thrust
"THE MOST SIGNIFICANT NEGATIVE EXPERIMENT IN THE HISTORY OF SCIENCE"!!!![]()
Before I get started talking about propeller thrust I want to set the stage with a dedication to Albert Michelson who spent his life measuring the speed of light. Born in Poland, his family came to the US when he was a little boy. He became expert with optics. In the mid 1800's the speed of light was known in a general way and Michelson, along with his helper Morely, made a device that would measure the speed of light to a degree of accuracy never known before. In fact they thought it so fine as to measure the effect of the earth's orbital movement on the speed of light according to the "ether" theory of light propogation that was current at that time. So they measured and measured and measured. They did indeed zero in on the speed of light but saw no orbit effects. The speed of light was the same no matter how it was measured. Michelson had enough confidence in himself that he published the results even though there was no explanation to be had. That was in 1883. Then in 1905 along comes young Albert Einstein who knows about Michelson's results. Einstein doesn't really explain it except maybe to say "accept it because that is the way it has been proven. The speed of light is always the same no matter how you measure it." And with that basis Einstein went on to figure his theory of relativitly and the rest is history. So just because you can't explain something you measured doesn't mean it is wrong.
NEXT...
PROPELLOR THRUST....
SO I MAKE A THRUSTOMETER...
DOES IT REALLY WORK?????
We'll rerun that old prop thrust article.
LFH17
FAST ROWBOAT, 17' X 3.5', 100 POUNDS EMPTY
Don't remember where I read this but 100 years ago rowing was all the rage, the sort of thing you did on for fun. They said its popularity dropped and died after the invention of the modern "safety" bicycle which replaced it for athletic recreation. The Herreshoffs in Rhode Island had a historic boat business going at that time making everything from huge racing yachts to dinks to torpedo boats. L. Francis Herreshoff carried on the tradition in the 1900's being a great designer, artist and writer and educator. I suspect anything he wrote is worth seeking out. I have a copy of his book SENSIBLE CRUISING DESIGNS which I think is a compilation of articles he wrote for THE RUDDER magazine about 50 years ago. Lots of really good stuff in there. Among it is a discussion of good rowing boats with a "cartoon" presentation of a 17' rowing boat that would be fast and able but also simple and comfortable and not extreme. John Gardiner, another legend in small boats whose writings you should seek out, elaborated on that LFH cartoon and presented offsets for his idea of that boat in his BUILDING SMALL CLASSIC CRAFT, VOLUME 2. Both L. Francis and Gardner were used to traditional lapstake construction and thought nothing of presenting such a design. But the special lumber and tools needed for lapstrake are not common at least where I live. So I got an order for the LFH design redone for taped seam plywood. Thus the design I call the LFH17. As with L. Francis' original the LHF17 has a narrow flat bottom making it a dory of sorts and is identical bow and stern
This boat will be a bit more complicated to build that most "instant" boats, I'm quite sure. For one thing it has three panels on each side to keep track of. And since they are long narrow pieces, all with a lot of flare, I doubt that it will jig itself like boats with wide plumb sides. So even though I show the expanded shapes of the individual planks I've also shown it made on a backbone or ladder frame so that it can be kept in proper alignment as it goes together. And, as with the original which probably had six or so strakes to each side instead of the three I show, the bottom bilge panel or garboard twists about fifty degrees in its journey from mid boat to stem and I would expect a fair amount of pushing and shoving required.
As you may know two prototypes were under construction. One by John Trussel in S. Carolina, was built on the frame I show in the plans. Here is a photo of his basic parts:
And here is a photo of his assembled boat. John said the building was at the limits of "instant" assembly and said he had to trim some of the ends of the planks to get them to fit easily. As I am writing this he has not yet launched the boat.
As John was building I heard from Doug Thomas in Florida who was building on a frame but his molds were females with the planks to be forced down inside, like this:
Doug did not trim anything but used lots of force to get the ends of the planks to fit, like this:
So maybe there is something fishy with my panel expansions.
Doug launched first:
Doug wrote: "My LFH17 is not yet done, but it is functional. I couldn’t resist trying it out once I had the oarlock sockets in. I had to have an on-the-water test to find the right spot for the foot braces, right?
I rowed it for 45 minutes last Wednesday. As expected, given the narrow waterline, it feels tippy getting in. However, once seated, one feels quite secure. There is noticeable flex to the hull when carrying it or when walking in the boat with hands on gunwales. There is no noticeable flex when rowing though. It might get a temporary thwart to make it easier to carry. Built in 5 mm Luan, it is light enough to carry but is a bit awkward due to the width.
The hull form seems to me a good compromise between tracking and maneuverability. It will track well enough if one pays attention. It can be turned readily. Today’s outing turned up a tendency to round up into the wind however. There’s not much wake and it carries well between strokes.
I averaged 4.3 mph with 7.5’ spoon blade oars, for a 3-mile outing. I have also tried 8’ spoons and 8.5’ Culler type blades. The 8.5’s are too long with hands overlapping on the pull. Eight feet is about right for me, but the 7.5’ work well too.
I am using the Gaco gated oarlock. See their Website. West Marine used to carry these, but I think they have discontinued them. This is the geometry that Phil Bolger prefers with the pin in front of the oar. This lock pivots on the pin, rather than the pin pivoting in the socket, so there should be less wear in the sockets. I am experimenting with just a 3/8” hole through the 1” oak riser block, gunwale, and a ½” backing block as the oarlock socket. I will probably make some oars with flats on the looms to match the flats on these locks. I am used to that configuration from all of my sliding seat rowing.
I left the hull in the female forms while I installed the gunwales and cross braces. I had to trim the form tops away from the boat to make room for the gunwale installation. It would have been better to plan ahead for this by making the molds shorter. Once the cross braces were in, I removed the screws holding the planks out to the molds and the planks relaxed only an eighth inch or so. I had to glass the exterior with the gunwales in the way, but this was not much trouble. I did elect to bevel the gunwale before installation. I cut it at 25 degrees. This is a bit of a compromise as the shearstrake angle varies a bit over the length. I planed the outer edge of the gunwale down to level in the ends in order to fit the cross braces. I added a third course to the gunwale for 2’ in way of the oarlock sockets in order to replace some of the wood lost in the bevel and to get a touch wider oarlock spread.
I drilled 1” holes in the stems for the painter or for tying down while car-topping.
It occurred to me that the boat would set up fine for carrying a passenger if it just went backwards. This does away with the need for a second set of oarlock sockets. The only hitch is that the bottom board gets narrow where the seat goes. I made my rowing seat trapezoidal so that it would fit between the chines (10” and 12” bases and 12” fore and aft). I took my wife for a ride this morning and it worked well with her sitting a bit forward of the cross brace.
So far, I am quite happy with the boat. While at the boundary of the stitch and glue technique, it is not too hard to assemble. It is probably better done in glued lap, but that seems foreign to your customer base. "
Later he added:
"My LFH17 weighs 73 pounds in its current state, so hauling it around is roughly equivalent to carrying my 16’ fiberglass canoe. It needs foot braces, a bit more epoxy, and paint yet. I used 5 mm Luan for planking, ¾” SYP ply stems, poplar for gunwales and cross braces, and oak for oarlock risers. There is not a lot of metal in it – small screws for planking to stems, ring nails for the second course of the gunwale, and four screws in the oarlock risers. (I secured the first course of the gunwale with clamps and blocks notched 25 degrees to the face while the glue set.) The interior is epoxy coated and there is the epoxy filled 6-ounce glass over the entire exterior.
I think I will hold off on adding the skeg for tracking for now. I will get a bit more experience to see how much nuisance it is in varying cross winds before I add weight and drag.
The foot braces for rowing with a passenger fall near amidships. I am thinking of running them from the bottom plank to the gunwale in ½” ply and filleting them to all planks. This should stiffen up the sides. However, there will be only about 2” landing on the bottom board to leave room for the seat. This could make a nasty stress riser. "
LFH17 needs four sheets of 1/4" plywood with taped seam construction. LFH17 plans are $30.
