(1mar07) This issue reruns the lugsail rigging essay. The 15 March issue will return to estimating power.
THE REND LAKE MESSABOUT WILL TAKE PLACE ON JUNE 8 and 9 AT THE GUN CREEK RECREATION AREA AT REND LAKE IN SOUTHERN ILLINOIS. MORE DETAILS WILL FOLLOW BUT IT MIGHT BE PRUDENT TO MAKE CAMPING RESERVATIONS IF YOU INTEND TO ATTEND.THE BOOK IS OUT!
Jeff McLamb built this "almost a Trilars". The hulls look to blueprint but the sail rig is more elaborate. Read about it at http://www.mclambs.org/trimaran/
Rigging A Lugsail
BASIC BALANCE....
TYING ON THE SAIL...
HALYARD/YARD ATTACHMENT...
THE TACK LINE....
THE SHEET...
SAILING ADVICE...
...we take another step in drawing a boat.
Blobster
Prototype plans for Blobster are $30.
