(1may07) This issue will rerun an old rowing gear essay. The 15 May issue will show me trying to measure rowing horsepower.
THE REND LAKE MESSABOUT WILL TAKE PLACE ON JUNE 8 and 9 AT THE GUN CREEK RECREATION AREA AT REND LAKE IN SOUTHERN ILLINOIS. MORE DETAILS WILL FOLLOW BUT IT MIGHT BE PRUDENT TO MAKE CAMPING RESERVATIONS IF YOU INTEND TO ATTEND.THE BOOK IS OUT!
Bill Nolen's Harmonica project, upside down. (Or is it a doghouse, or both?)
Rowing Gear
MAKING A SET OF OARS....
I'm going to show drawings for 7' oars which are about the most useful length for me.
WHAT KIND OF OARS....
The long narrow blades go against modern thinking of spoons, but for long distance rowing, long and narrow is the way to go. The average mortal can only pull so much of a load, in spite of what an Olympian might do. The Culler blades can match the mortal's pull. They might slip a bit when starting a heavy boat from a standstill, but once up to speed, the have full grip on the water. They balance better. They are less fatiguing. They have less windage. By the way, the oars of traditional Irish caurrahs have no blades on their oars. Neither do the paddles of some traditional kayaks.
WHAT YOU NEED...
For wood, I use 1x6 pine boards. The pattern shown in Figure 1 will just barely make an oar from a 1x6. I try to buy a single board long enough to get out both oars. For example, for a pair of 7 foot oars, I buy a board 14 feet long if I can. That way the oars will be a close match on weight, stiffness, and color I like to use soft wood like pine, It is easy to work and makes a light oar. It need not be clear wood although clear is easier to work Small solid knots are fine and look good too. I've never worried too much about grain because the sticks get laminated and tend to stay straight. But the straighter the grain the better.
For glue I prefer plastic resin "Weldwood" glue and doubt if there is anything better for making oars. Pour some in a cup and squirt in cold water until it has the consistency of normal woodworking glue like "Elmer's. I've found it to quite true that this glue will not set properly until it is a t 70 degrees F for twelve hours like it says on the can. But don't hesitate to use epoxy if you already have it on hand.
Now let's talk tools. The tool I use the most in making oars is a bandsaw and I hate to say that because it's not a cheap or small thing that everyone will have. The problem is that you've got to saw a 2-1/4" thick blank. Hand saws will work and the effort should get you in shape for rowing. After all, oars were invented long before the bandsaw. But I see Dave Carnell has built oars using his table saw and others have built oars with a sabersaw.
HOW TO BUILD...
First cut the 1x6 boards to the proper length. lay out the centerline with a straight edge. Then draw the pattern for the center piece, the one with the blade, around the centerline. Cut out the center lamination following the line closely with your saw, because the outer laminations of the blank are made from the off fall and there isn't much extra.
A ROWING SEAT/DITTY BOX....
Here is what the seat looks like for real, this one about 15 years old now. Here are some things you might keep inside the seat: spare oarlocks, a knife, some line, sunscreen, Vasoline, binoculars, compass, whistle, and some energy bars. Always take a lot of drinking water with you also when you go rowing.
OARLOCK SOCKETS...
If your hull's side have limited flare, say less than 15 degrees, you can make some cheap oarlock sockets that are as good as store bought. I got the idea for these, plus the oarlocks that follow, from Phil Bolger who used them on his Spur 2 rowing boat that appears in his book BOATS WITH AN OPEN MIND.
Here is how it's done.
What we have here is simply two metal plates bolted to the wale with the proper sized hole (usually 1/2") drilled in each. Phil had his made of stainless steel. I made mine out of aluminum and have had no problems. I used an aluminum yardstick of the type carried by lumberyards for use with drywall as the basic material. I think the metal is about 1/10" thick and about 1-1/8" wide. I cut the aluminum to 3" lengths, stacked them up and drilled the oarlock hole and the bolt holes all at the same time. Filed off any sharp edges. Clamped the plates in the proper position and drilled the wooden wale. Bolted the plates in position and that's it. These work well because the oarlock bears on the metal parts which are about 1" apart, a bit more than the usual shallow factory sockets. So far I haven't worn them out. By the way, it helps to grease any oarlock from time to time, ordinary Vasoline works well.
BOLGER OARLOCKS...
I haven't tried these but Phil swears by them. It is really a thole pin with a bracket to retain the oar. Phil has always said that thole pins are better than the usual factory oarlock where the oar centers directly over the rotating pin. With a traditional fixed thole pin the oar rotates around the fixed pin as it bears against it and Phil says that is a better motion than with the factory oarlocks. The pin shown here could also be fixed, the bracket rotating around the pin with the oar! I should try these.
We'll how you can cut the bevels that fit your bulkheads to the hull.
Robbsboat
ROBBSBOAT, SAILBOAT, 15' X 4', 550 POUNDS EMPTY
Robb really probably wanted a Matt Leydon cruiser like Paradox but was put off by the complexity and small size. It has been a while since I saw Paradox plans but I think the "complexity" of the design is mostly in the details that made such a small boat livable. And maybe the only way to make a small boat like this work well in the Paradox fashion is to install all those details. However, my feeling is that almost no one is going cruising the way that Matt does and can get by without many of those details. My feeling is that Matt was able to make those trips in his little boats by very careful and patient planning and lots of experience. And if anyone were to ask me if this new boat is safe for ocean travel my answer would be a very quick and loud NO. In the right hands, like Matt's, it might be but it is the old case of "If you have to ask, the answer is NO." because the question demonstrates you don't have enough experience to start with (like me).
But for a couple of days cruising on Kentucky lake, etc. by a small nimble person, it might work well, and that is what most of you will do if you are lucky. So the idea of Robbsboat is a small cruiser, totally enclosed, you sail it from the inside, you sleep in it, and it is supposed to take care of you and be self righting. Robb wanted it really sturdy so we have all 1/2" plywood with a bottom of double 1/2" plywood. Conventional construction including the only time I have ever used internal chine logs at Robb's insistance. That heavy plywood makes for a heavy boat - say 550 pounds stripped. The boat is supposed to be OK up to 1500 pounds total so a lot of gear can be stuffed inside. Some will think this is a two person cruiser, but they won't think that again after trying it on for size. If you tell someone they won't cruise with wife/girlfriend more than once I suppose 100% of them will disagree but you would be right for about 90% of them, so the boat will be a success 90% of the time. Much better than a really big boat that ends up being the wrong boat 90% of the time.
The sail rig shown is probably too large but then again it depends on the person and his cruising area. It is quite easy to reef or switch to a smaller sail since it is easy to get a balanced lug tuned up.
Eleven sheets of 1/2" plywood with conventional construction.
Plans for Robbsboat are $30 until one is built and tested.
