(15mar08)In this issue we'll rerun the important essay on rigging a lugsail. In the 1April issue I hope to show a fin propulsion system in a Roar2.
Rene Vidmer's nice AF4B project underway and he has never asked me about its headroom.
Rigging A Lugsail
BASIC BALANCE....
TYING ON THE SAIL...
HALYARD/YARD ATTACHMENT...
THE TACK LINE....
THE SHEET...
SAILING ADVICE...
TOON2
The sail rig is the same 96 square foot sharpie sprit that I used on Pencilbox and AF3. It started as the main on my old Bolger Jinni from 20 years ago. Very easy to make and use and efficient if you can live with a 21' mast on a 15' boat.
Prototype plans for Toon2 are $20.
The Mikesboat project has about all its major elements falling into place. He is working outside...
And a new Down Under Blobster, right side up....
