(1apr08)This issue will show a fin propulsion system in a Roar2. The 15 April issue will present how to rig a sprit sail.
THE REND LAKE MESSABOUT WILL TAKE PLACE ON JUNE 6 and 7 AT THE GUN CREEK RECREATION AREA AT REND LAKE IN SOUTHERN ILLINOIS. MORE DETAILS WILL FOLLOW BUT IT MIGHT BE PRUDENT TO MAKE CAMPING RESERVATIONS IF YOU INTEND TO ATTEND.THE BOOK IS OUT!
Dave Blowers sent this photo of his Toto in the Phillipines.
Flipper Powered Roar2
I GOT THIS LETTER WITH PHOTOS....
...from Doug Roney in Alberta. As you will see he fitted a Hobie flipper drive to his Roar2. I will present his letter and comment a bit at the end.
"HI JIM,
I have enclosed a CD with a number of photos of Roar2 that I have on the water with a pedal drive system. I had a great summer with it and got it into both the Atlantic and Pacific Oceans and it performed well. The ultimate compliment came from an old fellow who had worked for 35 years in a shipyard in Halifax, Nova Scotia. He looked the boat over while it was loaded on the truck and said, "Nice Hull".
I have named it WABI SABI which is a Japanese expression which, roughly translated, means Nothing is ever perfect, Nothing is ever finished and Nothing lasts forever.
An explanation for the photos:
Wabi 1a The finished product in a time trial using a GPS unit to measure top speed. For short bursts I can get 6mph but wouldn't maintain that for very long.
Wabi 1a1 Photo of a friend showing a better view of the pedal position.
I have included photos of how I modified things to make it pedal powered. I didn't want any thwarts since I needed to sit forward to pedal and backward to row. To compensate I put flotation tanks at each end and glassed the gunnels which made it much more rigid.
Wabi 1c Shows blocking added so I could add rudder and flotation tank on rear. Wood is in place and ready to be glassed in and port added.
Wabi 1e Shows preparation of front flotation tank.
Wabi 1g shows hole cut in bottom of boat for drive mechanism.
Wabi 1h shows side view of the box that mounts the drive and forms the base of the well.
Wabi 1j shows the rudder. Iron flat bar glassed into it so it is weighted.
Wabi 1k Pully mechanism to move the rudder.
Wabi 1l Steering mechanism to control the rudder. Flat iron bar glassed to side and magnets installed in wooden block. Slide forward and back to move rudder and magnet will hold it in place.
Wabi 1m This is the Hobi Mirage drive side view. Pedaling action moves flippers from side to side. Front on flipper is on a rigid rod while rear is flexible and bends to create a push forward as the flipper is moved from side to side.
Well for the drive with locking mechanism in place.
Wabi 1o Pedal drive seated in well.
Wabi1p Drive flippers through bottom of boat.
Wabi1q Seat and back support. The support is also from Hobi and is the backrest for their pedal powered kayak.
Front T of rack to carry boat on top of truck. Nose is stapped in place and then T swivels. Boat swung around and set onto rear rack. I designed and built the rack so I can still tow my fifth wheel trailer with the boat in front. Carried this way for eleven thousand miles this summer.
Regards, Doug Roney"
THANKS DOUG!!
NOW SOME COMMENTS...
I Googled around for the Mirage drive and it looks to cost about $500 basic with options on top. Not cheap. The top speed he noted of 6mph is about what you can pull with oars for a very short while. The Mirage flipper drive is not meant for really thin waters, needs a lot more draft than oars, which essentially don't need any. Also the oar drive needs no rudder. (HEY! Isn't that magnet rudder hold system simple and cool!) The flipper drive well must be open on top and fairly shallow. Doug said his was 6" deep and making it deeper would result in awkward seating. So the well might be a bit of a liability in rough water although I asked Doug about that and he said it was not an issue in his summer's use. I take it the flipper boat is solo only although Doug has his set up to row also and can be used to row two. I assume the flipper drive is forward only, no backing allowed. BUT, sitting forward has always been the dream of rowers and many much more complex systems have been invented to allow forward facing rowing. Finally the flipper system is essentially hands free - if you are a fisherman you have to have it. I thought Hobie's ads really pushed the fishing idea over touring.
Anyway, it is a cool setup and I thought you would enjoy seeing it.
FROLIC2
And Gary Blankenship's Frolic2 completed the Everglades 300 mile challange with him reporting sailing for hours at 7 knots or more. Last count he completed three of the challenges with a 4th overall in 2007. Here is Gary's Frolic2:
Plans for Frolic2 are $35.
The Mikesboat project has about all its major elements falling into place. He is working outside...
And a new Down Under Blobster, right side up....
