(15July09)This issue will rerun the rowboat setup essay. The 1 August issue will rerun the sail area math essay.
Charles Portway's English IMB.
ROWBOAT SETUP
NEXT TIME: We'll look at the effect of sweeping up a stern on a jonboat hull.
Mikesboat
I dunno if Mike ever built his boat but Bill Moffitt in Atlanta made one to run the Texas200. He is an experienced builder and sailor and made a thorough job of it in a big rush towards the end. Launching at the Texas200 was its first time in the water. His wife sewed the sails the day before he left for the cruise, and this was her first set of sails! The sail rig he wanted was a lug main with a sharpie mizzen. I drew those up for him and they are now included in the plan set. Here is his boat under sail:
Here is another photo of the boat beached beside Chuck Leinweber's mothership Caprice (which was designed originally for Bill Moffitt!) at the end of the cruise:
The cruise involved camping through several nights and Bill did something I have always thought about but had never seen. He pitched a standard tent in the large Mikesboat cockpit. A lot cheaper than a custom boat tent, for sure, but it takes a big cockpit to handle it. Mike also had some sort of center platform to fill the space between the long bench seats:
Well, three cheers for Bill and son Paul!!! As far as I know the 200 mile cruise went off without a hitch, the boat right on. But I suggest that most of us couldn't get away with going on a long cruise with an untested design.
And here is another Mikesboat, owned by David Chase...
Plans for Mikesboat, showing both sailrigs, are $45.
And a Family Skiff seen here at Rend Lake, report soon:
