(15Sep09)This issue will give a few thoughts about Birdwatcher cabins. The 1 October issue will repeat the bevels essay.
THE LAKE MONROE INDIANA MESSABOUT WILL TAKE PLACE ON SEPTEMBER 18, 19, AND 20...
Organizer John McDaniel writes...
"Check the messabout website: http://pwp.att.net/p/pwp-mwmess for the latest event news, photos of last year's happening, maps, and accomodation information. September is a busy month in the Lake Monroe area, so if your a hotel person rather than a camping type, you might want to book your hotel now."
Birdwatcher Cabins
HISTORY...A long time ago, in 1989, I built and launched my Bolger Birdwatcher. It was the second Birdwatcher ever built and I probably would not have built it if not for the words of the first builder (Ron Mueller ?) who told me the idea really worked. I had seen Phil's first drawings of it a few years earlier and in 1986 Phil wrote up an essay about the idea in the old Small Boat Journal. Phil later told me the Birdwatcher cabin was most likely the only real original thing he had thought up and I've got to tell you that in the 1800's I think anything you might imagine was tried. Later I decided that it took the invention of high strength clear plastic like Plexiglass to make the Birdwatcher idea work. Anyway, here is my old Birdwater a long time ago:
Not a great photo to be sure. I still have my Birdwatcher and see no need to replace it since it is still in fine condition, stored indoors.
THE IDEA BEHIND THE BIRDWATCHER....
...is that the crew rides inside sitting low as in an open skiff. Thus the crew weight, which is often the heaviest part of a small boat, is always down low. Next, they ride inside a waterproof Plexiglass "room", more or less just like you ride inside your car in its glassed in room. This is the cabin. Essentially all of the volume of the boat becomes the cabin. You steer from inside and handle the sails from inside. Here is an old photo of Bob and Sue Archibald riding up front in the cabin of my Birdwatcher:
Now, unlike your car the BW cabin was designed with a slot down the center, from stem to stern, wide enough to move about in. So you can stand up on the centerline and walk the length of the boat. At least in good weather. In bad weather the slot is closed with a fabric slot. You can sail in the rain without getting wet. In good weather with mild winds the skipper can sit up on the little aft deck and steer with his feet. Boy, I quickly learned there were many unusual combinations made available. If you lash the tiller BW would sometimes self steer very nicely. Then you walk to the forward end of the slot and watch the waves slide past the bow. And I learned that if you left the slot cover off while trailering you can look in your rear view mirror and see all the traffic behind you, through the open slot. With any other boat this size all you see in your rear view mirror is a big boat chasing you.
I never found the BW cabin to be uncomfortable. I think the dark tinted windows are a must but others seem to feel differently. Actually on a hot day you can always sit in the shade, and the sail usually provides a downdraft that flows through the cabin.
YOU GET A BIG CABIN...
...for the size of your boat, of course, since the whole hull is your cabin. In BW, and in most of the BW cabins I designed, you can sit at the tiller and see from stem to stern and all the volume is available to you. Here is a photo of the interior of Gerry Scott's IMB, a BW design I did that is only 13' long:
We had five adults in this boat at one time. The cabin is 8' long and meant to sleep one on the floor centerline but clearly it would sleep two good friends if they had a way to fill in the place between the seats to provide a flat that is 5' wide. There is no way you could get such a large and airy cabin in anything this size except in a BW type hull. My 19' Jewelbox has room to sleep four adults in its cabin. (The original BW would sleep three, one spot missing because of the use of a centerboard (which is off center)).
AND YOU HAVE SAFETY...
In some ways I think this is the real benefit of the BW cabin. With the crew weight down low and the cabin top up high, most BW hulls will self right from a full knockdown with no one getting wet. And with no extra ballast required. The original BW has a 1" thick bottom with 1/4" elsewhere so the weight was down low to start with.
Now, with a normal cabin hull the crew sits in the stern raised up a couple of feet, at least, because they must see over the cabin top in front of them. So if you have a 4' deep cabin for some sort of sitting headroom then the cockpit needs to be raised up say 2' for crew vision. And their weight goes up with them. Ballast must be added down low to counteract that in a knockdown. I think as a general rule of thumb a normal cabin hull that is supposed to self right will have maybe 40 percent minimum of its weight in ballast. So a 1000 hull might have 400 pounds of lead down low under the bottom. BW doesn't need that (but it is still prudent to test your BW in shallow water to be sure). So a BW hull might be 40 percent lighter than a similar traditional hull. So there is a lot less weight to trailer around.
And a lot less draft. My BW, over 24' long and about 700 pounds empty, draws less that 3" of water with the board up! As you see in the first photo of it, a quick pull on the snout will get it a third of its length out of the water. Launching is simple to say the least. I like to show this photo of Chris Feller's great Philsboat pulled over half way out of the water stern first. Try that with your ballasted fin keeler!
Philsboat is only 15' long but it will hold three or four adults like IMB. You can see how I tinkered with the original BW design as I went along. In general I tried to change the things that bothered me about the original BW. So mine are smaller (my BW is 30' long from trailer tongue to rudder tip), with simple squared off cabins (my BW has some double bevel fitting in those fancy sloped cabin ends), and simple square off sterns (got away from the welded rudder linkage required by the pointy stern and Phil had no intention of ever putting a motor on BW and thought we were all rat race wimps for wanting one). And I went back to that other great Bolger reinvention, the leeboard.
And speaking of safety, you can't fall out of the thing as long as you don't go walking on the cabin top. Imagine sailing with a bunch of kids in a flush deck boat. You'd get a little worried. Now put them inside the BW cabin and let them run around. They can see out just like in a car.
DOWNSIDES....
I'd say there are only two real disadvantages to the BW cabin. One is that the Plexiglass is expensive and in some areas might be hard to find. As I recall way back in 89 I spent $1200 on my BW project and over $400 of that was in the Plexiglass. I dunno if there is anything better than Plexiglass for this. Some have tried Lexan but Lexan is apparently softer and more prone to scratching and impossible to polish. Also Lexan seems to be harmed by some common chemicals, like the stuff they put in mosquito spray.
The other downside was a bit of a surprise to me. It's the flip of the "I can see outside anywhere" idea. The problem is that everyone else can see inside. So you must keep things tidy and use discretion. Especially with tinted glass you can't see out after dark. But if you light a lantern I assure you that everyone can see you inside even if you can't see them. So curtains might be a good investment.
WELL...
I am really sold on the BW idea and will continue to draw them.
Philsboat
Plans for Philsboat are $45.
