(1Mar09)This issue will take a look at mizzen sails. The 15 March issue will rerun the lugsail rigging aritcle.
Mizzen Thoughts
ONCE I HAD A MIZZEN....
...which was on my old Bolger Jinni, my second homemade boat. That back about 1982 or so, before digital pictures and when I was still a young man, sort of. I kept it for about ten years before it finally rotted out due to rainwater as it sat outside on the trailer but eventually it inspired AF3 which is about the same size and keeps the Jinni mainsail. But Jinni was a small open beach cruiser, 16' x 4' with an open central cockpit that was long enough to sleep in, sleeps two if you are good friends. It had the buoyancy/storage boxes fore and aft and a leeboard. Sound familiar? It is a formula that worked so well I copied it over and over in many new designs, probably more than Bolger did.
The Jinni had a small mizzen making it a yawl. I learned a lot from it. The sail area totaled about 120 sq ft, huge for a 200 pound hull that was 4'wide max. Of course you could sail in a whiff of a breeze but it probably would have been better overall with a bit less. I think the mizzen was about 25 sq ft and it is probably still out in the shop.
A NEW BAG OF TRICKS...
Before the Jinni my experiences were first in a Hobie 16, then a Snark Mach 2, and then in a Bolger Teal. All had a single main (even the Hobie went through its first season without a jib). When Bolger drew up the Jinni he put the mizzen on it with no input from me. But mizzens were a very common feature on Bolger designs. Mizzens allow one a new bag of tricks...
STABLE ANCHORING...
....that is the mizzen will act like a tailfeather on an anchored boat. It is especially important I think with the usual keelless daysailor or beach boat which has almost no resistance to lateral motion except for a board dropped down underwater such as a leeboard. Without the mizzen stabilizer they will skitter across the water swaying from side to side which does nothing for your night's sleep or your anchor set for that matter. But while I'm talking about this you might try such a boat anchored with and without the board down. I had a theory that with the board down the boat will skitter less but given the right shift in wind a light boat might start moving forward and that will add to your problems. So try it both ways.
SELF STEERING...
....is a huge feature of the mizzen. It usually only works well while sailing on a reach, which is handy. To work the main is sheeted for fast going and then the mizzen is sheeted in to trim the helm, the force you feel on the tiller, to zero. At that point you should be able to let go of the tiller and she will forge ahead on course. In theory the system has enough stability that small shifts in course will be corrected by the mizzen. My experience was that with the light Jinni, which was very quick to turn and responsive to the tiller, not to mention wave bumps and wind shifts, it didn't work so well. Strapping the tiller down seemed important. Otherwise any wave would cause the tiller to twitch and the boat would follow it quickly. I once tried raising the rudder out of the water while self steering with the mizzen and thought it went just as well as far as self steering was concerned. But later, when I finished the much longer and steadier Birdwatcher, I found the Birdwatcher with no mizzen would self steer as well as the Jinni with a mizzen as long as the tiller was strapped into position. On boats with long deep keels I would think the mizzen system would be much more effective.
HEAVING TO...
...OK, here is where the mizzen on the little JInni really payed off. Let's say you are out solo sailing a small light boat in a rising wind that is starting to give you a scare. You want to reef. How are you gonna do it??? You must go forward to drop the main but you can't leave the tiller for a second. If you do she turns sideways and over you go. Even Bolger would say to stick with it and worry your way to shelter, beach and reef. But I found the Jinni would heave to safe with its head to the wind in anything as long as the mizzen is sheeted in tight and the main sheeted loose. Then you can raise the rudder (to keep the boat from swapping ends since it will drift in reverse), go forward to drop the sail, secure a reef, then back to lower the rudder, ease the mizzen and let the boat swing a bit sideways before sheeting in the main and get moving forward. I don't think it could be done any other way. Bolger said it could indeed be a life saver.
SAILING IN REVERSE...
...If you keep the above idea in mind and imagine that the shelter you seek is downwind from your current position and you aren't too keen on turning downwind with a 200 pound boat with 100 square feet of sail set on a 12' boom while your hull is but 4' wide. If the boat rolls enough for your boomed out sail to dip into the water you will capsize. And perhaps you have no desire to risk a jybe with that long boom, or for that matter to take off downwind in a big blow because after all you can't depower the thing once you get going without risking a knockdown. I found I could leave the main down or flapping and just go in reverse with the mizzen sheeted tight. You can't really steer it but the Jinni would drift in a stable reverse at about 2mph. When I finished drifting past my shelter I would ease the mizzen, sheet in the main and sail to the shelter on a reach. I think the reach is the safest sailing point because you can depower the main quickly and keep moving but I could be wrong.
SAILING FORWARD....
...in a really big blow you can actually often sail on a reach or to windward on mizzen alone. You would think the boat's balance would be all messed up but Bolger pointed out that the furled main has enough drag to keep the boat from constantly heading upwind and stalling. I only did short hops with the Jinni this way but I see Chuck Leinweber apparently took long legs this way, and with good speed, with his Caprice in the windy Texas 200.
THE DOWNSIDE...
... I capsized the Jinni twice and in both cases the mizzen may have been to blame. I was still young and stupid (now I'm just stupid) and thought I and the boat were bulletproof. So out I went into a big blow pounding upwind on a big shallow lake. After a couple miles of that I turned downwind sheeting the main out with the mizzen still pretty tight. She got sideways on a wave front, rolled and broached. (Was the sheeted mizzen the last straw that day??) There were no other young and stupid boaters around so no one around to help (it would not have been safe) but I got it righted, bailed out. By the time I got it all sorted out and ready to sail again I was abeam my original launch point so there is where I discovered I could drift backward with the mizzen sheeting in tight and then sail on a reach to shelter instead of trying run downwind in a big blow.
The second capsize was in totally different conditions. A spring day with almost no wind, everything sheeted in tight. Then a big quick blow, maybe a dustdevil in Texas, hit. I got the main unsheeted and flapping but couldn't get to the mizzen sheet fast enough and over she went on windpower alone. Then it was calm again. My rudder unshipped but in the calm conditions I could gather it up along with my other gear, learning that you need to keep your rudder secured, don't rely on gravity which won't work when you are upside down.
So about then I decided that little boats don't need mizzens while daysailing. The boat becomes easier to build, setup and sail. I rebuilt the Jinni, had to as it was rotting quickly, and added a cuddy cabin and moved the main aft and left off the mizzen. It was then reborn as the AF3 on my drawing board.
BUT BIGGER BOATS CAN USE THEM...
I continued to draw mizzens on the larger boats. They are much more likely to go cruising, much less daysailing, and the mizzen is almost mandatory. Here is Sandra Leinweber relaxing at the tiller of Caprice:
On a bigger boat the ability to trim the tiller force is more important. Here is Garth Battista at the helm of his Cormorant, clearly the mizzen is putting in power and the tiller load is very mild:
THEN SOMETHING HAPPENED...
Gary Blankenship had been sailing Frolic2 in Florida. He is quite experienced and was getting involved with the Everglades Challenge, 300 miles of press on regardless. He wanted a mizzen for all the above reasons. Now there is a subtle design point involved here involving "sail area math". Normally the center of all the sail areas on the boat is placed directly above (or slightly aft of) the boat's underwater area, which on all my boats is centered on the leeboard. If the sail area goes forward then the boat will have lee helm, the bow will blow off downwind, and sailing to windward will be terrible and sometimes no even possible. If the sail area is too far aft then the boat may head up into the wind more than you want. On the larger boats I fudged it so the total area, including the mizzen's, is a bit aft of the leeboard. There is a general feeling that the aft sails are blanketed a bit by the fore sails, thus have less force than one might expect. I have seen where some designers might draw the sail balance using only half of the mizzen area. So there is guesswork involved. So you might think when you add a mizzen you would need to move the main forward a bit to maintain balance.
But Gary was just gonna add the mizzen and leave the main as is. Why not? If the mizzen throws the balance off why not just ease its sheet. You can still use it to heave to and anchor, which are its main advantages. So Gary just did it:
IT WORKED... He finished fourth overall in the big race with this rig.
So, with that in mind, I started adding mizzens to smaller boats by designing the basic layout to balance without the mizzen. Then add a small mizzen which would be totally optional in use, when you go cruising. I think Bill Moffitt's Mikesboat, modified to have a big lugsail and the tiny mizzen, was the first I drew that way. Here he is in the Texas200, on the boat's first time afloat, flying along with no problems (that I was told about).
Shortly afterward I drew up the Caroline design with the same plan. But Caroline's mizzen sail was not ready when the first cruise occurred. Apparently she sailed fine with main alone, as planned. But without the mizzen achoring was found to be too unpleasant if not too risky on the Maine coast. Next year we will know.
THE MIZZEN FUTURE???
Well, it looks right now as if we could just add a small mizzen to any design where it will fit and get most of the benefits without giving up a single sail layout for quick daysailing. I have designed for Steve Chambers such a rig for his Wooboto which is pretty much a bolt on deal.
It uses a simple bolt on box mount which has a slight taper to secure the mizzen mast.
We should know if a few months how it all works out. Steve is an active boater and is probably mizzening around as we speak.
Blobster
Prototype plans for Blobster are $30.
