(1Sep09)This issue will repeat the taped seam essay. The 15 September issue will give a few thoughts about Birdwatcher cabins.
THE LAKE MONROE INDIANA MESSABOUT WILL TAKE PLACE ON SEPTEMBER 18, 19, AND 20...
Organizer John McDaniel writes...
"Check the messabout website: http://pwp.att.net/p/pwp-mwmess for the latest event news, photos of last year's happening, maps, and accomodation information. September is a busy month in the Lake Monroe area, so if your a hotel person rather than a camping type, you might want to book your hotel now."
Taped Seams
THE INNER SEAMS... ![]()
TAPING THE OUTER SEAMS....
FINAL WORK...
YOU'RE DONE!
Trilars
And another builder tried a half sized Laguna as a proof of concept thing and claims he ain't gonna sail it!
Here is a full sized Laguna hull ready for finishing:
