(15Jan09)This issue will finish the knockdown essay. The 1 February issue will discuss buoyancy chambers and swamping.
Family fun on Gordo Barcom's Laguna.
Knockdown Recovery 2
One reason I was looking forward to the test was to scope out the situation which Norm Wolf ran into with his Normsboat where the capsized boat floated nicely on its side and was easy to right but had its centerline slot pretty close to the water. Here is a photo of the situation.
THE CAPSIZE...
I pulled it over and thought in a subjective way that the maximum righting force came at about 20 degrees which is what I expected. Almost any unballasted sharpie seems to behave like that. I continued to pull until the cockpit coaming was about to go under and flood the cockpit. Max said that was at about the limit of his gauge, 40 degrees. I was surprised that the boat still had substantial righting ability at that point unlike my old Jinni which capsized twice in its career, both times it seems like way before any water came over the rail. But the AF3 was still hanging in there and you might be able to recover right up until then. Max had covers over his oarports which leaked slightly - a good indication that it is time to release the sheet although I can't imagine anyone seriously sailing one of these over 20 degrees of heel in a regular way.
UPDATE 2007...
...I heard of three capsizes with swampings this year, two in AF3 and one in a Frolic2. What they all had in common was someone standing in the open slot top at the time. Clearly that won't work - the weight has to be in the cockpit and the slot well covered and secured.
LADYBUG CAPSIZE UPDATE:
MORE PONDERING...
Caroline
CAROLINE, SAILBOAT, 18' X 6', 750 POUNDS EMPTY
Caroline started as a blend of Philsboat and Frolic2. The idea was for a little more cabin room than Philsboat and hopefully with the same seakeeping ability that Frolic2 has demonstrated. I made it a little deeper and wider and with a longer cabin than Philsboat. It all added up to about 30% more cabin volume. But it is also more boat to build and pay for and haul so the other boats, which are lighter and cheaper, still haven’t been made obsolete as far as I am concerned.
One interesting side to this sort of house design is that if you add a motor well, as this one has, the stern gets pretty busy since the only way you can run a normal tiller to the rudder is under the aft deck. To get a good swing of the rudder that aft deck needs to be short and wide if that motor is to live there too. I think I have it all crammed in there such that it might work but even so the rudder is well offset to one side, as it was successfully done with Philsboat.
The builder wanted a yawl rig (she wants to coastal cruise the Maine coast) but I added the mizzen as I do now, keeping the basic balance such that you could sail it without the mizzen.
I'm still carrying Caroline as a prototype even though she was completed and cruised in the summer of 2008. Problem was that the mizzen wasn't ready in time for the cruise so they went to sea without. She sailed fine but I underestimated the anchor situation in Maine where the tides won't let you beach a heavy boat. Any boat like this will swing at anchor in a wind and so did Caroline. The mizzen is supposed to stop that so hopefully we shall see in the 2009 cruise if she works AOK with the mizzen. But here are some photos of the first launch/cruise:
You can see that these Birdwatcher cabins are simple and roomy.
Looks like six sheets of 1/4", ten sheets of 3/8" and three sheets of 1/2"". Taped seam construction.
Plans for Caroline are $35 until one is built and tested.
