(15Mar10)This issue rerun the lugsail rigging essay. The 1 April issue will look at ideas to strengthen masts.
MUST SEE WEBSITE!!!!
...Our old buddy Garth Battista of Breakaway Books has escaped! He towed his Cormorant and his family, between East Coast blizzards, from New York to Miami and is now acruisin' with them all in the Bahamas, etc.. He keeps an updated log at
http://blog.mailasail.com/seafever
He is on a never ending search for ice cream and internet access. When he finds both at the same time he posts photos like:
Garth is like most of us, an inland waters guy who went out and built a boat for himself. Seems like just yesterday he sent photos of his first Toto. THREE CHEERS AND GOOD LUCK!
Rigging A Lugsail
BASIC BALANCE....
TYING ON THE SAIL...
HALYARD/YARD ATTACHMENT...
THE TACK LINE....
THE SHEET...
SAILING ADVICE...
Laguna
Laguna, Sailboat, 23' X 5.5', 450 POUNDS EMPTY
This boat was designed for Duckworks to run the Texas200, 200 miles of brisk downwind running they say in the somewhat protected waters of the Texas intercoastal waterway. The boat was supposed to be cheap and quick and hold two crew with floorspace for them to sleep on board. The basic idea I had was to stretch the Mayfly16 with an 8' plug in the middle. In the end I kept the basic cross section and stretched it out with a simple flat iron skiff shape. The bottom is the width of a sheet of plywood which simplifies things even more. The first doodle looked like this:
I drew it up in detail getting this:
And a card model from the detailed drawings looked like this:
My cross seats are supposed to be big and comfortable and removable to give sleeping room on the floor. Each crewman has his own stateroom.
The sail rig was to be a split rig with identical lugsails fore and aft with the option to sail with just one of the sails mounted in the center, like this:
I think the single sail option would be preferred if sailing solo since that fore mast is way up yonder and one may not be able to handle it and the tiller at one time.
The prototype was quickly built by Gordo Barcom in Texas and here he is blasting along with family and polytarp sails straining. It was clearly a fast roomy boat:
Then another, the Blue Laguna, was built and run in the 2010 Everglades Challange, 300 miles from Tampa to Key Largo, by Andrew Linn and Michael Monies. This boat had very little testing time as far as I know before the race. But they finished in 5 days and a bit but I think they slept in motels for two of the nights while the "press on regardless" guys were daring the night waters. Here they are launching off the beach (a requirement for this race):
And then pushing off in shallow water (there is a Sea Pearl behind them for comparison):
Finally a really nice photo of them approaching one of the three checkpoints in the race:
I think both Gordo's boat and the Blue Laguna have been modified in details from the blueprint but the rigs and basic hull features all look correct. I've noticed that no one takes sleeping floor space as seriously as I do but that is OK.
Well, I was thrilled. My main caution would be that this probably is not a good solo boat due to its size and split rig. I think it might be a good family boat in that there is plenty of room for everyone and a rope for all idle hands to play with. The other caution might be that, even though the boat has big buoyance boxes, it also has large cockpits to swamp in a knockdown and it will roll upright with a lot of water to bail. So you note on Gordo's boat he has inflated fender tied to the mast head, an idea to reduce the carnage of a knockdown.
Plans for Laguna are $45. It is all simple nail and glue construction needing six sheets of 1/4" plywood and five sheets of 1/2" plywood.
And the Vole in New York is Garth Battista's of www.breakawaybooks.com, printer of my book and Max's book and many other fine sports books. Boat is done, shown here off Cape Cod with mothership Cormorant in background, Garth's girls are one year older. Beautiful job! I think Garth is using a small lug rig for sail, not the sharpie sprit sail shown on the plans, so I will continue to carry the design as a prototype boat.
A Twister goes together in good shape. He moved the cabin bulkhead aft for more cabin, less cockpit:
