(1December10)This will rerun the taped seam essay. The 15 December issue will rerun the bevels essay.
Taped Seams
THE INNER SEAMS... ![]()
TAPING THE OUTER SEAMS....
FINAL WORK...
YOU'RE DONE!
Trilars
