(1May10)This issue will review small boat rudders. The 15 May issue will rerun the article about putting a new bottom on AF4.
MUST SEE WEBSITE!!!!
...Well, Garth's Excellent Adventure is over. He towed his Cormorant and his family, between East Coast blizzards, from New York to Miami and went acruisin' with them all in the Bahamas for two months. He kept an updated log at
http://blog.mailasail.com/seafever
He was on a never ending search for ice cream and internet access. When he found both at the same time he posted photos like:
Garth is like most of us, an inland waters guy who went out and built a boat for himself. Seems like just yesterday he sent photos of his first Toto. I hope you all will get to read his log and see what a great job he did of the trip. Thanks again, Garth!
THE REND LAKE MESSABOUT WILL TAKE PLACE ON JUNE 11 and 12 AT THE PINTAIL LOOP OF THE NORTH SANDUSKY CAMP GROUND AT REND LAKE IN SOUTHERN ILLINOIS. ALL OF THE SANDUSKY CAMP GROUNDS ARE FULL AS FAR AS I CAN TELL FOR THAT WEEKEND. THE GUN CREEK CAMP GROUND THAT WE USED FOR YEARS HAS BEEN CLOSED. BUT OUR BOATERS HAVE RESERVED SOME OF THE SITES AT SANDUSKY SO YOU (AND I) MIGHT PASS THAT WAY FIRST SINCE USUALLY SEVERAL TENTERS CAN SHARE A CAMPSITE. IF NOT, THEN I WOULD TRY THE WAYNE FITZGERRELL STATE CAMPGROUND WHICH IS ON THE MAIN CAUSEWAY LEADING TO SANDUSKY. THEIR WEBSITE SAYS IT IS STRICTLY FIRST COME FIRST SERVE, NO RESERVATIONS ALLOWED. IT IS A VERY QUICK DRIVE FROM THERE TO SANDUSKY. HOPE TO SEE YOU THERE!
Scott Gosnell takes his new Mayfly14 out for a spin.
SMALL BOAT RUDDERS
GENERAL...
I have no rule that I use to size a rudder. I just draw something that looks like the proper size for the boat. I always make it shorter than the leeboard with the idea that the leeboard will bump the bottom first, you will notice that and prepare for shallow water or underwater objects with unlashing the main sheet and having a firm hand on the tiller. But the question arises, "How much rudder do you need?"
I think the worst condition the rudder will usually see is when running downwind with the sail boomed way out like this:
There might be conditions of imbalance during close wind sailing when the rudder will be overpowered but not if you have done your "sail area math". So what have we in the above picture? The sail is boomed out all the way and its force is pulling straight ahead but many feet off to the side. The hull has a drag equal to the sail's force and the boat has reached its terminal velocity so to speak. The distance between the sail force and the drag creates a torque that the rudder and leeboard must balance. I suppose on an old square rigged boat the sails would still be on centerline and this condition hardly occurs and you might hardly need a rudder running downwind. Perhaps the worst case would be the old catboats with huge booms, short hulls and very shallow rudders.
In the sailing I have done with my own boats the only case of ever running out of rudder came under this downwind condition with the original WeeVee. It had a gaff sail, was only 7' long, and I was trying a shallow end plated rudder. In a brisk downwind no amount of rudder deflection would hold it on course, it would swing around and round up into the wind. I found I could "tack" it downwind by sailing a broad reach instead of downwind. I tried various sizes of endplates but finally went to a deeper conventional swing rudder as shown in this article. That cured it! I gave up on shallow rudders.
I think Chris Feller has suggested the rudder on Mixer was too small. Maybe so but the clear answer on how to fix such a situation is simply to make the rudder bigger, deeper in particular since deeper is in general more effective than wider. Almost any rudder I've ever designed was something that hung on the stern transom so changing it is pretty easy, unlike say a rudder that is mounted to a shaft that runs through the hull. Anyway I wanted to point these things out before getting into the meat of this older article.
BACKGROUND...Here is an article I wrote a while back that appeared in the great paper magazine BOATBUILDER. I've included copies of it in my prototypes catalog since then. The article shows how I've made rudders for my own small boats.
RUDDER BLADE...
SINK WEIGHT...
RUDDER STOCK...
TILLER/HOIST LANYARD...
SHEET FAIRLEAD...
HINGES...
THE CARY HINGE...
Here is his description:
Blobster
Great job, Miles!
Plans for Blobster are $45.
A Twister goes together in good shape. He moved the cabin bulkhead aft for more cabin, less cockpit:
