(1July2012) This issue will rerun an old old article about propellor thrust. The 15 July issue will start a series about making an "instant" boat (originally aired on 15 Jan 2002).
A quiet moment at the Texas 200. That's John and Rosa Goodman in his Hapscut. Check it out at http://www.youtube.com/watch?v=jc7ssNkiRn8&feature=youtu.be |
Measuring Prop Thrust
"THE MOST SIGNIFICANT NEGATIVE EXPERIMENT IN THE HISTORY OF SCIENCE"!!!![]()
Before I get started talking about propeller thrust I want to set the stage with a dedication to Albert Michelson who spent his life measuring the speed of light. Born in Poland, his family came to the US when he was a little boy. He became expert with optics. In the mid 1800's the speed of light was known in a general way and Michelson, along with his helper Morely, made a device that would measure the speed of light to a degree of accuracy never known before. In fact they thought it so fine as to measure the effect of the earth's orbital movement on the speed of light according to the "ether" theory of light propogation that was current at that time. So they measured and measured and measured. They did indeed zero in on the speed of light but saw no orbit effects. The speed of light was the same no matter how it was measured. Michelson had enough confidence in himself that he published the results even though there was no explanation to be had. That was in 1883. Then in 1905 along comes young Albert Einstein who knows about Michelson's results. Einstein doesn't really explain it except maybe to say "accept it because that is the way it has been proven. The speed of light is always the same no matter how you measure it." And with that basis Einstein went on to figure his theory of relativitly and the rest is history. So just because you can't explain something you measured doesn't mean it is wrong.
NEXT...
PROPELLOR THRUST....
SO I MAKE A THRUSTOMETER...
DOES IT REALLY WORK?????
THUS I WROTE IN 2003...
...And then Eistein emailed an explanation. Except I've forgotten his name. Anyway, the horsepower rating of your motor may be very optomistic for use in this sort of analysis for several reasons.
1...The manufacturer probably lied in the first place (except in the case of a 10hp motor where they are sometimes under rated). So my 15 might be a 14 or 13 or something.
2...In the old days power was measured with just the powerhead on the measuring brake and did not include losses in the power train. I think newer motors have the measuring brake connected to the prop shaft so that transmission losses are included in the power rating. They say the losses due to the power train are about 10 percent. So now my old 15 is maybe really 12 or lower at the prop.
3...I suspect the drag of the lower unit in the water can be considerable. I have no idea what it is but I have seen "racing" lower units and they are indeed sleek and small compared to the usual factory "torpedo". Their props are tiny too as I recall, very steep pitch and they must cavitate terribly until the racer gets up to speed.
4...And then Einstein emailed to say the BEST efficiency of any water prop is maybe 50 percent! So if my engine says 15hp on the cowl, maybe 12 of that is getting to the prop and 6 of that is actually effective in pushing the boat, which is what the Hullforms program was predicting! In fact now I think I'm doing pretty good. Where goes the other 50 percent? I would guess it is used up swirling the water around.
Brucesboat
BRUCESBOAT, POWER SKIFF, 19' X 5', 250 POUNDS EMPTY
Bruce was looking for a large powered canoe but couldn't find one for sale. He said they still make them by hand in Maine but he was in California and you couldn't expect to buy one anyway unless you showed up with money in hand on the day the builder happened to finish one. So he wondered if the row/sail skiff Woobo couldn't be redone as a long lean powerboat. It's not the first time that has been mentioned. Ray Laviolette had the first plumb bow Roar, predecessor to Woobo, built up in Michigan for rowing and both he and his builder thought the shape could be modified for low power.
Brucesboat followed pretty quickly from that. I kept the plumb bow, easy to build and lots of folks like its looks. The multichine shape is very good in rought water. it's not as stable as a flattie of course but sometimes I think it is safer in that you must walk on the center of the boat because you can;t step on the slanted bilge panels. Your weight is always close to centerline where it should be. I made the main cross section 6" wider than Woobo and a bit deeper. From the center aft the bottom is straight and flat. The sides could be that way too, but I pinch them in a little and sweep the sheer up in the stern a bit for looks. I gave it a skid/stiffener on centerline so she would stay put on the water. These multichine boats have little lateral resistance on their own and sometimes would just as soon go sideways as forwards.
I'm a big chicken on power and would keep this one at 10hp max. I think the main problem will simply be the weight of the motor, fuel and skipper in the stern. I've never designed a downward hook into the bottom to cope with bow wanting to go skyward, although some swear by that hook. The boat could be trimmed with wedges glued to the bottom stern if needed.
I kept Woobo's light taped seam construction and the plywood bill looks like three sheets of 1/4" and four sheets of 3/8". That's about 250 pounds of plywood and I would expect the finished boat to weigh about that much. The bow is boxed in with a storge/buoyancy chamber, the middle has a stout boxed thwart, and the stern is boxed in with a draining motor well. There are actually two places in the boat long and wide enough to lie down in. It might be a reasonable expedition boat given a small motor that burns little fuel and a canoeist skipper who is used to roughing it.
Brian Nimmo built the prototype:
He brought it to Rend Lake with fresh paint and a new 10hp four stroke...
And I hopped aboard for a ride. He had his gps with him...
Very nice I thought. He will be using it to run rivers. We figured we were at about 800 pounds total. At 8 mph she started to lift on plane and at full throttle was doing 15. She banked her turns nicely, something you can't expect a true flattie to do.
Plans for Brucesboat are $30.
And the first Brucesboat, very complete and I got to ride in it at Rend Lake. A full report soon.
The Texas Hapscut, built by John Goodman, is shown here doing a low flyby on the Texas200. This year he took his wife! This boat looks like it is motor planing but it is not, just using strong steady Texas200 winds. (He has scarfed some material on the stern to finish the boat with a built in motor well like Laguna. Good idea.) Full report soon.
This is the Paulsboat sailing canoe. It is done and as you see here has been sailing. You might search youtube for "paulsboat" and watch. Built by Paul Moffitt of the famous boating Moffitts. Full report soon.
