(15August13) This issue will review making lead sink weight for your rudder. The 1 September issue will show how to rig a lugsail.
Making Sink Weights
WHY SINK WEIGHTS????....
MELTING THE LEAD...
This is Tidmarsh's setup.
Cormorant
All best, Garth
