(15December13) This issue will discuss trailering issues. The 1 January issue will take on the topic of beam/stability.
Mark Smith in sunny Florida plugs away at his Dockbox deluxe. |
Trailering Plywood Boats
...WHEN TO TRAILER...
...TOW VEHICLE...
...TRAILER TYPES...
A low trailer is best.
...CUSTOM BUNKS...
...TONGUE WEIGHT...
First you need to locate your boat fore-and-aft on the trailer such that the tongue weight (the weight that rests on the hitch ball) is 10 to 15% of the total. I doubt if there are a dozen people in the world who know the weight of their boat/trailer combination. A fifteen footer like my plywood AF3 probably weighs 400 or 500 pounds with a typical trailer. So 50 pounds would be a good tongue weight. (It's also all most of us care to lift and push around. If your trailer tongue is too heavy to lift with reasonable effort you will need a wheeled trailer jack on the tongue.) Slide the hull fore and aft on the trailer until you've got it. Be ready for a surprise. Most likely a sailing or rowing hull will be well aft of the typical power fishing boat location the trailer manufacturer expected. I found a trailer meant for a 12 foot powered skiff is just right for a 16 foot plywood trailer sailer.
...NOW FOR THOSE BUNKS...
WINCH POST
...GOAL POSTS...
...SIDE BUNKS...
...TIE DOWNS...
...LIGHTS...
...FINALLY.....
SPORTDORY
SPORTDORY
Sportdory plans are $20.
