(15March2013) This issue will continue the old "drawing a boat" essays that first ran in 2005, in particular the use of the Hullforms program. The 15 March issue will continue the topic.
Andrew Linn, famed for burning his new Laguna on the beach after the Tx200, helps build boats at www.toledocommunityboathouse.com , including this QT power skiff shown here being used by a young family as a canoe. |
Drawing Boats 4
BACK TO THE BOBSBOAT DESIGN...
Let's take a quick guess at its displacement using the prismatic coefficient method discussed last time. We will put the draft at 9" which is where the chines and stern will start to immerse. I would expect the boat to go fairly well up until that point, then it will slow dramatically. Here is the endview:
First we will construct a "prism" with a length as long as our waterline when the draft is 9". I will estimate that as 18'. Then the prism will have the same cross section as this boat's maximum underwater cross section. So that cross section will have as shown above a bottom 4' wide and a top 6' wide and a depth of .75' deep (9" draft). That cross sectional area is .5x(4+6)x.75=3.75 sq ft. And the total prism volume would be 3.75 x 18 = 67.5 cubic feet. Now apply a "prismatic coefficient" of .55 as discussed in the last issue and we would estimate a max useful displacement for Bobsboat of 67.5 x .55 = 37 cubic feet of water, which is 37 x 62 = 2300 pounds.
That I think is quite a lot. I would at this time estimate an empty weight of the hull at perhaps 500 pounds and maybe another 100 pounds for the motor. Add four adults at say 700 pounds total and you are looking at about 1200 pounds total. So there is quite a surplus. One thing I must remember is that this boat is to have its motor mounted inboard in a slot that will eliminate a triangular shaped volume of water that is 4' long, maybe 2' wide, and 9" deep which eliminates about 180 pounds of displacement. Anyway, the important point is that we have enough and if someone wants to take on more folks the boat will handle it.
Always do this sort of calculation as soon as you can. For example if this were to be a ballasted sailing cabin boat you might increase hull weight to maybe 700 pounds and then add 700 pounds of ballast and have a starting weight of 1400 pounds before adding any people or gear. (It should still work.)
MIGHT AS WELL TRY A COMPUTER MODEL...
At this stage you will do well to make a computer model using something like the Hullform program. You should be able to download a free demo version of the program which will suffice for this work by clicking on the Hullform link at the bottom of this web issue. Hullform is not an "instant" sort of program. You will have to supply it with the information needed to define the hull shape of your boat - no program could do any serious work without that.
So I go back to the line drawings that I made a few issues ago and measure offsets at every two feet, plus another set at station 11 of this 20' hull so I have a section at the hull's maximum beam. Then I call up Hullform and start a model and start plugging in those offsets. Eventually you will get pretty good at it and be able to knock out a useful model in a half hour or so. Here is my Hullform model of Bobsboat:
Looks like a boat to me. The graphics will show you big goofs in your offsets but maybe not small goofs. I'm not sure how fine the grid needs to be but I'm quite sure that having ten or so stations is plenty to get a good handle on the numbers. I did not model in the motor slot but I'm sure it can be done. Hullform was I think meant for serious ship design and is not challenged much by this small boat. The version I use most was written for DOS, that is it is older than Windows. It runs very quickly on any computer. I would suspect the newer versions require more power and have a lot more graphics.
But even the free demos will allow you to see your hull in three dimensions, even will shade things to a certain degree, like this:
And this:
Still looks like a boat to me and I see no need to change anything.
PUTTING HULLFORMS TO WORK...
Pictures are nice but Hullform will do some real quick work for you. Again you need to supply it with all the info it needs to do that work, such as weight and center of gravity. At this stage you will have to guess at those.
So I used the above model to check on the displacement calculations. Essentially you tell Hullform the boats weight and cg location and it will tell you the draft needed and how much the boat is pitching. Usually we want the boat to sit level when loaded so I found by a few trials that this hull wants its weight centered 11' from the bow to float level. That is fine since it is also the max beam location. (The real boat, with the motor slot, will want its weight more forward.) Once you have that cg location for level trim you can plug in a few weights and just read off the resulting drafts. Here is what I got for Bobsboat:
500 pounds - 3.4" draft (probably the weight of the empty boat).
800 pounds - 4.5" draft (probably the minimum operating weight with skipper and motor).
1000 pounds - 5.2" draft
1200 pounds - 5.8" draft (a good maximum weight, say four adults on board).
2400 pounds - 8.96" draft (is that close to our first guess or what!)
I should add that at this point the program has not really solved much that we weren't able to figure by hand quickly. But Hullform will also very quickly solve the problem of righting moments at various angles of heel and that if done by hand is almost a life's work. Doing those calculations by hand is so tedious that essentially it was never done for small boats. In the example Bobsboat, which should also be a fine sailing hull, the program would also need to know the vertical cg location. Once supplied with the hull shape and the total weight/cg situation, Hullform will crank out a full righting moment graph in a few seconds! (But don't get the idea that you can supply it with a weight/cg estimate in a few seconds.)
ANOTHER FEATURE...
that I noticed in the newer demos is the ability to give a chart of drag/speed for your proposed hull. I'm don't really know the source of the math behind the estimates. You may recall that a couple of years back I built a "Thrustometer" and measured the thrust of a few of my outboards while they were pushing my AF4. Then I compared those thrusts to the Hullform estimates. The comparison was OK, a good starting point I think. Here is the proposed chart for Bobsboat:
When I look at this I see what all slow speed hulls experience - a "hull speed". As you see, drag rises very quickly at about 5 knots. The usual estimate for "hull speed" in knots is something like 1.3 times the square root of the waterline length (in feet). So if we had an 18' waterline then we would estimate 1.3 x sqrt18 = 5.5 knots. And the above chart sort of agrees with that. I'm not sure if we have gained a lot of new information but it is worth while to look at. Hullform will make curves for a range of weights (the above is for 1200 pounds).
Some day I'd like to be able to use the above charts to get a handle on horsepower requirements, a task we tried back with the Thrustometer. If you look at the above there would be a temptation to say, "Hey, a 30 pound thrust trolling motor will push this at 5 knots." And that might be true. But in any breeze the wind drag will quickly outrun the water drag and you will get nowhere or go backwards. From my experience with Birdwatcher, the answer to powering all boats like this is that you need between three and five hp. BW went 6mph with my 3.5 Clinton wide open and about 6mph with my 5.5 Johnson wide open. From the above chart you can see why - the slope of the drag curve is so steep at the "hull speed" that a lot more power gives only a little more speed. That would be true until the boat starts to "plane". In the above chart you see the black line which is the start of the planing line. Somewhere in between the red line and the black line there is a transition. But a hull with a fine stern like Bobsboat or Birdwatcher really won't plane well at all as far as hull trim and controlability are concerned and you should not think of planing that type of hull. The extra power of the 5.5 on Birdwatcher has a real advantage in that I can run at say 4knots at a whisper quiet third throttle in calm conditions and still have some extra to fight the bad conditions.
When we come back to Bobsboat in April we will start the hard core drafting - determining the prefab shapes of the panels.
FROLIC2
And Gary Blankenship's Frolic2 completed the Everglades 300 mile challenge with him reporting sailing for hours at 7 knots or more. Last count he completed five of the challenges with a 4th overall in 2007 and 7th in 2012. Here is Gary's Frolic2 on the launch pad just before the start. Note the row of fenders mounted on the cabin to be used as beach rollers but also as capsize protection since boats like this can swamp if the cabin is not well corked and there is weight forward.:
And then the actual race launch, that is Gary showing us his backside with crewman Chuck The Duck Leinweber:
I should add that the little mizzen is Gary's addition and is quite valuable on a long cruise, and by my experience usually a bother for a short daysail. Although Gary has never used a motor on his Frolic2 he still retains the well and saw no need to change the offset rudder.
Plans for Frolic2 are $35.
