(15 February2022) We review trailering plywood boats. The 1 March issue will cover small boat rudders.
A closer look at Sean McCambride's Piccup Pram.
jim@jimsboats.com
Trailering Plywood Boats
...WHEN TO TRAILER...
...TOW VEHICLE...
...TRAILER TYPES...
A low trailer is best.
...CUSTOM BUNKS...
...TONGUE WEIGHT...
...NOW FOR THOSE BUNKS...
WINCH POST
...GOAL POSTS...
...SIDE BUNKS...
...TIE DOWNS...
...LIGHTS...
...FINALLY.....
IMB
IMB plans are $30.
