(1 May 2021) We capsize an AF3. The 15 May issue will review mast tabernacles.
Armed with a fresh vaccination I ventured forth again into the world and quickly found an engineering print shop that did very good scans at a good price (alas, a 40 minute drive). Chuck at Duckworks has been updating the catalog so they are available for sale only as instant downloads, about 30 designs available as I write, adding 5 to 10 more per week.
AS FOR REND LAKE MESSABOUT 2021,
I think it is time to call it off again. Covid numbers are steady in this county slightly higher than last year at this time. But there is no way to figure how it might be mid June and there has not really been any interest. So let's try again next year.
Left: Ken Preston's AF4breve looks pretty much done to me...
AF3 Capsize Tests
"Hi Jim:
I now have 14 days of sailing in on the AF3. Alas, no pictures yet of it sailing on the water for the same reason as ever, no one else around to take a picture. Most days I am the only boat on the lake. Had one sail where we traveled 20 miles in one day. We did a 6.5 mile section that day in 1 hour 10 minutes with the small sail (69 square feet) on a beam to broad reach (lots of wind). Also managed to turn the AF3 on its side that same day. The AF3 floated well was easily uprighted, boarded and bailed out. Everything in the cuddy stayed dry and we managed to not loose any of our gear. But that is not what I am writing about....."
"I climbed on from the stern. I have a small step on the stern that also doubles as a support for my mast cradle. I put my hands on the stern deck and placed my foot on the step and climbed on board. I must take a photo of this step and send it to you. With the step it was easy to reboard and I could walk around in the cockpit with the water in it and bail it out. Gord then reboarded over the side, which was much more difficult and his choice not mine."
"Hello Jim:
Herb"
Herb looks to have gone through all his tests without disturbing any gear because he had it well stowed. Very important. But a tight well secured fabric cover of the cabin slot would be a good idea in rough going. It should help keep a big wave from sloshing into the cabin and upsetting your day. You must remember that in the conditions that might cause a real capsize things will be a lot more trying.
Blobster
Great job, Miles!
Plans for Blobster are $45.
1aug20, Prop Slip, Oracle
1feb21, Bulkhead Bevels, Toto
15feb21, Trailering, IMB
