(1December10)This will rerun the taped seam essay. The 15 December issue will rerun the bevels essay.
Taped Seams
THE INNER SEAMS... ![]()
TAPING THE OUTER SEAMS....
FINAL WORK...
YOU'RE DONE!
Trilars
15dec09, Ballast Again3, Raider
1jan10, Knockdown Recovery 1, RioGrande
15jan10, Knockdown Recovery 2, Caroline
1feb10, Emergency Flotation, Mayfly16
15feb10,IMB Capsize Test, IMB
15jul10,Texas200a, Mikesboat
15aug10,Texas200c, Cormorant
