(1 September 2018) We measure prop thrust. The 15 September issue will review taped seams.
TIME FOR THE INDIANA MESSABOUT!
Fellow Messers,
July 4th is behind us and mid-September is closing fast. We just wanted to send a short reminder that the 26th occurrence of the Lake Monroe Midwest Messabout will be September 14, 15, & 16 -- mark your calendars.
Go to https://sites.google.com/site/lakemonroemidwestmessabout/home for additional information and feel free to drop us a line if you have any questions. If you're planning to attend, and want us to add your name/boat/homeport to the website's "Who's Coming" list just send us an email.
Hope to see all of you in just a few weeks. We have the ice cream maker standing by!! Pass the word to all your boating friends. Regards, John & Susan McDaniel
Measuring Prop Thrust
"THE MOST SIGNIFICANT NEGATIVE EXPERIMENT IN THE HISTORY OF SCIENCE"!!!Before I get started talking about propeller thrust I want to set the stage with a dedication to Albert Michelson who spent his life measuring the speed of light. Born in Poland, his family came to the US when he was a little boy. He became expert with optics. In the mid 1800's the speed of light was known in a general way and Michelson, along with his helper Morely, made a device that would measure the speed of light to a degree of accuracy never known before. In fact they thought it so fine as to measure the effect of the earth's orbital movement on the speed of light according to the "ether" theory of light propogation that was current at that time. So they measured and measured and measured. They did indeed zero in on the speed of light but saw no orbit effects. The speed of light was the same no matter how it was measured. Michelson had enough confidence in himself that he published the results even though there was no explanation to be had. That was in 1883. Then in 1905 along comes young Albert Einstein who knows about Michelson's results. Einstein doesn't really explain it except maybe to say "accept it because that is the way it has been proven. The speed of light is always the same no matter how you measure it." And with that basis Einstein went on to figure his theory of relativitly and the rest is history. So just because you can't explain something you measured doesn't mean it is wrong.
NEXT...
PROPELLOR THRUST....
SO I MAKE A THRUSTOMETER...
DOES IT REALLY WORK?????
AN EMAIL FROM EINSTEIN....
came after I wrote this a long time ago. No, not really from Einstein but I have lost the email over the years. He said my guess that only 30% of the horsepower goes into pushing the boat is about correct! Because even the very best props are only about 50% efficient that way. Over the counter props would indeed be in the 30% catagory.
OliveOyl
Plans for OliveOyl are $35.
15sep17, Plywood Butt Joints, Philsboat
1jan18, Trailering, Normsboat
1feb18, Bulkhead Bevels, Toto
15feb18, Sail Rig Spars, IMB
